HP500 Blowby >
HP500 Blowby
HP500 Blowby
Old 07-20-2003 | 09:58 AM
gofastpilot
Question HP500 Blowby
I recently put into service 2 freshened 1994 HP 500's. The motors were rebuilt with new rings,bearings, severe duty valves,new valve springs and new teflon valve seals.
My question is regarding a small amount of blow by coming out of the valve cover breather hoses which exit into the spark arrester. The teflon valve seals were installed per a tech article from PB mag where as the tech guy stated that when installing the exhaust valve seals you should remove the tension spring that squeezes the seal to the valve stem thus allowing I believe better oiling for the guide/stem. Could the blow by be caused from the loose fitting valve stem seal? The intake valves are using full tension on the seals........gofast
Old 07-20-2003 | 11:07 AM
paradigm shift's Avatar
Blow by is caused from piston rings not sealing. The oil seals on valves will not cause it.
paradigm shift is offline
Old 07-21-2003 | 06:38 PM
gofastpilot
Just discovered # 3 cylinder has no compression all the rest have normal pressure @ 150 psi. Pullin the motor tomorrow.............gofastpilot
Old 07-21-2003 | 08:32 PM
Maybe just a head gasket. Hope it did not hurt to many parts. My first post assumed it was running on all 8 cylinders.
Old 07-22-2003 | 05:58 PM
gofastpilot
Pull the heads today found 4 melted pistons. The #3 cyl. that didn't have compression had the most damage.Amazingly the cylinders are fine and there was some aluminum metal transfer on the heads. The problem was that I made a fatal mistake when I set the ignition timing. The harmonic damper has 2 timing marks. One is TDC and the other is 34 deg. BTDC. I mistaking took the 34 deg mark as the TDC mark, the rest is history.I may be 50 years old but I'm sure learning alot............Gofastpilot
Old 07-22-2003 | 07:20 PM
Turbojack's Avatar
Did you have the timing off on both motors?
Turbojack is offline
Old 07-22-2003 | 07:27 PM
Well at least you do know why and I bet it will not happen again. I learn every day and some of my boat motor learning has been expensive just ask my wife. On second thought don't ask better left as is.
Old 07-23-2003 | 10:07 AM
gofastpilot
turbojack.....no I didnt screw up the timing on the other engine because I timed it off of the proper timing mark. In my pursuit to get the engines running I neglected to accent the timing marks with a light colored paint which would have clearly shown the differance in the 2 marks.My mistake again...........gofastpilot
Old 07-23-2003 | 10:53 AM
Offshore Addiction
boy,I'll bet that motor made a ton of power for a few minutes!
Naughty Kitty
45
08-05-2008 06:56 AM
niceguy
1
07-19-2008 10:44 PM
kennyo
5
07-27-2006 11:40 PM
Lofty
0
12-03-2004 11:16 AM
HiPerf2000
11
04-16-2004 06:25 PM
