Prop "Labbing" or "Blueprinting" >
Old 07-26-2003 | 03:03 AM
BAD-HABIT's Avatar
Default Prop "Labbing" or "Blueprinting"
What type of gain minimum and maximum should you see in top end mph? I have seen it written that on a top quality prop you should see 2-3 and with lesser quality prop anywhere from 3-5mph....So should I deduct 2mph min? I realize EVERY prop is different but I am looking for a baseline.
BH
BAD-HABIT is offline
Old 07-26-2003 | 03:48 PM
throttleup's Avatar
Typically you will see 2-4 MPH thru the process of Blueprinting. This is dependant upon several factors, of course. You have to take specifics into consideration in order to
A. Determine if you are in the best prop for your application. Sometimes speed gains can be had simply by dialing in the boat and finding the appropriate prop.
B. Then Blueprint and see further speed gains.
What are the specifics on your boat?
There may just be some speed to be had!
Julie
Throttle Up Propellers
877-842-6855
throttleup is offline
Old 07-27-2003 | 05:50 AM
R Addiction's Avatar
AT Cult Member #3
Julie I have some questions for you I'll call you on monday!!
R Addiction is offline
Old 07-28-2003 | 11:17 AM
HOUSTONPROP's Avatar
Default labbing results
usually we see a 2 mph gain ,but most of all the propeller is alot smoother, and will have better midrange accleration than a stock propeller,also the planing time is quicker.Darin 281-580-PROP(7767)
HOUSTONPROP is offline
Old 07-28-2003 | 12:30 PM
Payton's Avatar
Charter Member #927
What exactly is the dif between labbing and blueprinting?
My understandingis that a blueprinted prop you have all blades equal and perfect. Is a labbed prop blueprinting+, thinned blades and a brushed finish?
Payton is offline
Old 07-28-2003 | 01:31 PM
Default Labbing or Blueprinting
yes,They are the same.
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
Ben@SRP
14
10-13-2006 09:11 AM
ActiveFun
04-26-2004 09:42 PM
mikesufka
12-26-2002 11:23 AM
