Prop ???'s
Old 08-02-2003 | 08:05 AM
bowtie89
Default Prop ???'s
My 206 is running great now only its tough to get up on a plane. The boat is supposed to have a 21 ptch prop and I am running a 25 the only problem is the rpms are already at 4700 with a 350 magnum if I put on a 21 ptch I am worried that they will go to high what do you think???
Old 08-02-2003 | 09:20 PM
Payton's Avatar
Charter Member #927
Go with a 23" and maybe have the edges cupped a little more. It should plane better than the 25. By adding the cup it will still act more like a 25 when up on plane
Payton is offline
Old 08-04-2003 | 03:19 AM
HOUSTONPROP's Avatar
Question prop question
They best thing to do is ,we could pitch the prop down 2"in pitch which will make it plane alot quicker,than thin the blades some and add cupping to make it run fast on the top end,also trim tabs are nice to have as well./Darin 281-580-7767
HOUSTONPROP is offline
Old 08-04-2003 | 10:05 AM
bowtie89
Default sounds good
How much would something like that run me?? Is that like reconditioning the prop?? The speedo is only showing about 35 I hope that its off but I don't think it is. I think the boat is supposed to see 55-60 with the 350 mag!! I want at least 50!!! How much will it raise my rpm's and do you know what the max rpm's should be for that engine??
Old 08-04-2003 | 10:31 AM
Default bowetie89
You have mail. 'Darin
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
