22' Scarab Prop >
22' Scarab Prop
22' Scarab Prop
Old 08-05-2003 | 02:10 PM
robyw1's Avatar
Default 22' Scarab Prop
I'm new to OSO and just recently purchased a 1998 22' Scarab. I'm very pleased with the boat overall however I know it needs a new prop. At this time it has a 21" pitch Mirage Plus that is rough around the leading edge of the blades. As it is it will push past 5000RPM if the rev limiter or I were to allow it, and has a tendency to blow out in the turns.
I'm looking for good overall performance in the top end. I have read good things about the Mirage Plus, Revolution 4 and Bravo 1. The engine is a stock 7.4 MPI 310HP using the Bennett tabs. Has anyone on the list found a good setup for this boat? I would greatly appreciate your experiences.
Much Thanks
Roby Warwick
Spring, TX
robyw1 is offline
Old 08-05-2003 | 03:10 PM
dadinator
Had this same boat and ran a 25P Mirage, 3 blade. Ran 68mph on a good day on gps. Prop would blow out on hard turns at slow speeds but all around it was good. Even pulled water skiers in excess of 200lbs. Very sensitive to trim but very predictable.
Old 08-06-2003 | 07:10 AM
97BossHammer's Avatar
I agree with dadinator.....I am currently running a 23p mirage plus on my baja and have talked to several scarab owners running the exact same. I'd like to get a 25p though.
97BossHammer is offline
Old 08-06-2003 | 07:33 AM
patrick22309
I have the same setup on my 23ft stingray and I can pull a 23p Mirage past 5K. Thinking of going to a 23Plus or 25P to get the rpms down. I would stay with the mirage plus because you will get more bow lift and that scarab should really get light then.
Old 08-06-2003 | 09:46 AM
throttleup's Avatar
GREAT INFO ABOVE! Our experiences have been just as mentioned with the 22' Scarabs. The Mirage Plus is a great prop for this boat.
Robyw1: You are running to high of an RPM for that motor you really need to be at 4200-4600 RPM at WOT. By increasing the pitch you will bring the RPM down back into the torque band of the motor. ]
It sounds like it might be a good idea to try testing some props to get you there. We have the test prop program for just this! Feel free to call me any time and we can do some prop testing and get you dialed in!
Julie
Throttle Up Propellers
877-842-6855
throttleup is offline
Old 08-06-2003 | 11:14 AM
robyw1's Avatar
Thanks everyone for all of the great information. I stumbled on to OSO about a month ago and have found tons of useful information. It is greatly appreciated
Roby Warwick
Spring, TX
robyw1 is offline
Old 08-06-2003 | 09:01 PM
Elite Marine's Avatar
I had a Baja Hammer running a 24P Mirage Plus. Either 23 or 25 modified. It was the perfect pitch for the boat, great hole shot, mid range and top end.
Elite Marine is offline
Old 09-11-2006 | 08:27 PM
Default Re: 22' Scarab Prop
I run a scarab 22 -98 with the 7.4L carburated engine and im spinning a Miragle Plus 25". My maximum rpm is 4600 and the revlimiter kicks in at 4650 so it seems to be the perfect pitch for my setup
Meyern is offline
03darkshadow
Scarab
25
03-27-2009 12:28 PM
customtouch
Scarab
7
07-30-2007 04:39 PM
speedboatr
Scarab
10
07-20-2007 02:53 PM
ferraristyle
Scarab
5
01-16-2006 06:05 AM
MIKEHTMSR24
04-10-2002 11:28 PM
