Dual battery installation. >
Old 08-07-2003 | 10:08 PM
buck183's Avatar
Default Dual battery installation.
I now this topic has been touched on about a thousand times. But it matters more this time because it's me.
Putting dual Optimas in the Scarab tomorrow night. Make sure I have this right.
Hot from both batteries go to selector switch, one on each post from switch. Hot from alternator goes to common on switch. Ground from motor to one battery and then jumper a ground from that batter to second one.
Yes or no?
Buck
buck183 is offline
Old 08-07-2003 | 10:51 PM
blown formula's Avatar
Yes!!
Don't you love it when a plan comes together!!
blown formula is offline
Old 08-08-2003 | 07:49 AM
buck183's Avatar
That was easy.
Thanks!
Buck
buck183 is offline
Old 08-08-2003 | 08:07 AM
Audiofn's Avatar
Charter Member #232
yup you got it
Put your best foot forward!
Audiofn is offline
Old 08-08-2003 | 08:08 AM
Audiofn's Avatar
Charter Member #232
Oh and YOULL GET YOUR DANCE!!!!!
Audiofn is offline
Old 08-08-2003 | 08:18 AM
mr_velocity's Avatar
Default Re: Dual battery installation.
Yes or no?
Buck
No, you need two switches if you have two batteries and two motors. Then alt from port motor goes to port battery and alt from starboard motor to starboard battery. If you only use one switch then when you are running on Batt 1 only batt 1 will charge.
mr_velocity is offline
Old 08-08-2003 | 08:43 AM
I hate to disagree... but, I have had two Formula's from the factory with dual batteries, both with ONE switch. It is true however, that if batt 1 is selected it will only charge batt 1. That is why when running, you should have the selector in "ALL" position. I only use the 1 or 2 selector if one battery is discharged to get the strongest to start the engines, then switch to the weak battery to charge it up first.
The selector switch must be one that aloows switching when charging or it can damage an alternator. Most switches made now days do allow switching.
You are good to go now!!
Old 08-08-2003 | 11:59 AM
buck183's Avatar
Guess I should have specified....single engine application.
Buck
buck183 is offline
Old 08-09-2003 | 08:04 AM
buck183's Avatar
Thanks all!!!! I now have dual Blue Top Optimas with Eddie Marine Billet hold downs. SWEEEEET!!!!
Buck
buck183 is offline
cbgenrl
Powerquest
3
04-09-2005 09:46 AM
1stfntn
5
04-08-2005 08:51 AM
gferdon
Fountain
10
01-20-2005 09:39 PM
MiamiVice
17
12-23-2004 10:25 PM
kcgbjc
12-16-2004 02:10 AM
