Ballistic Propellers >
Old 08-25-2003 | 07:44 PM
mopower's Avatar
Toxic FORMULA
Like I said earlier , I got one. Wanna try it ? PM me. Make you a heck of a deal
mopower is offline
Old 08-26-2003 | 03:33 AM
Daniel
the Ballistic prop is one of the best props I ever had.
I tested it on a Baja Outlaw 24 with supercharged 502 and it was the fastest one, faster then any Mirage! The only problem is the rubber hub, no solid hub is available!
With more then 450hp the rubber hub spins thru!
Old 08-26-2003 | 01:38 PM
JON242
I think due to the blade design you don't get as much bow lift as you do from a Mirage.
Old 08-26-2003 | 02:45 PM
markt111's Avatar
will be able to shed some light in a couple days, atleast for me, I just talked to MOPOWER and he sending the 23*, I'll have some feedback shortly
markt111 is offline
Old 08-26-2003 | 07:54 PM
mopower's Avatar
Toxic FORMULA
OSO comes thru again
mopower is offline
Old 08-28-2003 | 11:24 AM
Mr. Demeanor
I have a 26' Liberator with a single 454 and tried just about everything. I now run Merc Rev4 and love it. 2mph faster. The biggest advantage I found was that I can trim up much higher before the prop blows out. IF you can test drive a Rev4, I would do it.
You can run any of the new Merc props, you just need an adapter hub, about $30. The 19p Rev4 dropped my rpm by 600 compared to the 19p OMC Viper I had but still ran faster up top. My slip dropped dramatically. They do make the Rev4 in a 17p.
Old 09-01-2003 | 10:39 AM
mopower's Avatar
Toxic FORMULA
Mark???? Well , how'd it do?
mopower is offline
fastboats
01-30-2007 06:04 PM
dhlaw
06-19-2006 09:38 PM
Car Biz
04-28-2006 08:00 AM
SCARABJ
02-20-2006 08:15 PM
BAD-HABIT
11
07-28-2002 11:44 PM
