forward problem with mercruiserII tranny >
Old 08-24-2003 | 05:02 AM
Default Thank you for all answers and help
it was a damaged Teflon seal rings (i hope)
does anybodey have this manual online or know where i can buy it and is it a manual to an engine because i have manual for trs drive and there is not anything about trans II
mattis75 is offline
Old 08-24-2003 | 09:04 AM
Audiofn's Avatar
Charter Member #232
You can still get all the manuals from Merc. You willl more then likely have to order them. I have I think 6 manuals to cover my outdrive, tranny, and engines.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-24-2003 | 01:57 PM
spectra32's Avatar
Mattis,
Email me. I have the section of the manual that you need.
[email protected]
Joel
spectra32 is offline
Old 08-26-2003 | 04:29 AM
Scott B's Avatar
Spec,
Is that info e-mailable by any chance? I am having some Merctrans issues (occasional slippage in forward) and want to service the unit properly.
Thanks!
Scott B
Scott B is offline
Old 08-26-2003 | 07:11 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Scott B, mine slipped too under power, till I rebuilt it. When I took it apart all the clutch plates were worn to almost nothing. ie. no friction material left. Luckily, it's an easy rebuild.
Note- when I replaced the teflon seal on the shaft I went with an aftermarket 'bronze-filled teflon seal' said to have a higher tolerance for heat.
Brian Kamrath
[email protected]
martiniboat is offline
Old 08-26-2003 | 08:32 PM
Scott B's Avatar
Brian,
Where did you get the seal, and did you note the P/N?
I am going to change the fluid, check the screen and the line pressure this week, if thats not it I guess it's time to pull the motor. I think I will do the extra (5 - 6? ) plate conversion while it is out.. I figure a new cam is part of the cost of rebuilding the tranny
Thanks!
Scott B
Scott B is offline
Old 08-26-2003 | 09:18 PM
spectra32's Avatar
For whoever wants, email me and Ill send you a pdf of the repair sections for both the trans and the TRS drive. The file size is big, so keep that in mind (9.5MB in size). I have included a torque specs, full exploded views, and part numbers also. It's good info to have on hand for when these things crap out.
Joel
[email protected]
Old 08-27-2003 | 07:18 AM
Hi Scott, I don't have a part number for that bronze filled teflon shaft seal, I purchased it at a 'hydraulic' shop. (It's 1")
As far as the plates, I ordered through Mercruiser, when they arrived they were all in FORD boxes! I paid way too much for them, about three times more than I should have, if only I had known...well, lucky for you I have the part #s.
4-pc. plate C8AZ-7B442-A
5-pc. plate C9AZ-7B164-A
one spring C0AP-7B070-A
and one sealing kit from Mercruiser/Quicksilver 63222A 1(contains all seals required)
rear seal for trans. housing CR 100 50
My serial # for trans. 0013262
Model# MCM-D
Later, Brian Kamrath
innthered
11-24-2004 07:25 PM
bigwheel
2
07-18-2004 08:02 PM
Buddy OO
06-09-2004 06:49 AM
dap100
2
07-28-2003 04:00 PM
Sydwayz
10-31-2002 01:27 PM
