253 Convincor >
253 Convincor
253 Convincor
Old 08-19-2003 | 12:48 PM
Default 253 Convincor
I have a 2000 253 Convincor, we pulled out the 502 and tried a little experiment. I replaced it with a 555 ci all alluminum, 6lbs boost procharger, EFI with a FAST programmable fuel injection. Running a XR 1.50, Imco hyd steering, still playing around with drive spacers to get the x dimension right but I think I'm close. The engine dyno'd at 830 hp, at 5100, over 800 ft lbs torque above 4000 rpm. The fastest GPS number I have seen so far is 101 mph at 5100 rpm, 34 pitch bravo 4 blade. Have to run alot of trim tabs to keep the hull stable above 80 miles per hour. I'm looking for some advice on IAC programming or any other Fuel Injection parameters that affect idle transition. The engine is a little temperamental when docking, wants to die when shifting from neutral. Any help is appreciated.
RACER8 is offline
Old 08-19-2003 | 01:44 PM
dyno's Avatar
Charter Member #655
Holy Crap Batman!!! those are great #'s!!!!! you might want to talk to Checkmate300 he runs a big hp single engine check its a turbo but I think he could help.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 08-19-2003 | 02:30 PM
dlbCheckmate's Avatar
Try JimV.
dlbCheckmate is offline
Old 08-19-2003 | 03:27 PM
Crazyhorse's Avatar
Jeez, some of the planes I fly don't go that fast,,,,,,,,,,,,
Crazyhorse is offline
Old 02-19-2004 | 08:45 AM
Did you get that idle thing going? Id like to o the fast computer myself. Greg
HPJunkie is offline
Old 02-19-2004 | 11:10 AM
I had a '98 253 and it was a great boat. It would dance a little when it reached the upper 70s, but still tons of fun. Good luck!
Pure Energy is offline
alliedtf1
4
02-13-2008 02:36 PM
onesickpantera
Checkmate
18
02-02-2006 02:17 PM
onesickpantera
09-10-2005 07:32 AM
Vinny P
Checkmate
7
07-17-2004 10:56 PM
