Best Oil Coolers >
Best Oil Coolers
Best Oil Coolers
Old 09-02-2003 | 09:19 AM
aTX427's Avatar
Default Best Oil Coolers
I am looking for a HD oil cooler that accepts -16 water lines. I would prefer one that mounts to the block but may have to settle with the remote mount type.
Thanks in advance.
aTX427 is offline
Old 09-05-2003 | 03:13 PM
Strip Poker 388's Avatar
Rob
Teauge had the biggest oil coolers I've seen , they donnt mount to the block tho ,on the oil line i ran #12 on the water i think it was 1 inch pipe, the get the from a industrial supply for diesel engines.dan olsen had one that mount to block but smaller
Strip Poker 388 is offline
Old 09-07-2003 | 08:30 AM
GO4BROKE's Avatar
A friend of mine put a TCM on his 850, solved his oil temp problems. Eddie marine has one with the same dimensions for half the money ($300), I was wondering if they would work as well, I will be buying a pair of coolers this winter.
[img][/img]
GO4BROKE is offline
Old 09-07-2003 | 11:44 PM
Krumbsnatcher's Avatar
Paul PFaff racing engines in HB California sell a 3" oil cooler dual with thermostat that also will mount to your block.
Here is a pic! It does not accept a 16 hose more like the standard water line, I know I wasted some cash trying to make it fit a -16.
I have the bracket you can have it for $25, you will just need to buy the cooler braces, it is nice an shiny and cost me $60. I tried to use it, but my motor sits to low and the cooler hit the stringer so I had to move it.
Krumbsnatcher is offline
Old 09-07-2003 | 11:45 PM
Here it is with the water line attached!
Old 09-12-2003 | 04:58 PM
GO4BROKE's Avatar
Originally posted by BUDAH
Those coolers from eddies are killer quality and work very well ,,,I use them alot and they are about 1/2 the Teaque units and the fit and finish is perfect
Thanks, thats exactly what I wanted to hear!!
[img][/img]
GO4BROKE is offline
dean51267
14
08-05-2006 12:07 AM
johnnyboatman
15
02-23-2006 01:21 AM
Shah Mat
13
11-30-2003 08:46 PM
BRUCE SEROFF
6
03-27-2003 04:39 PM
