Building a bigger bulldog >
Old 09-09-2003 | 07:56 AM
XCAV8's Avatar
Default Building a bigger bulldog
Ok here's what i'm looking to do............
build a big cube bullet proof engine , natural carb motor, making say from the 500 - 600 H.P. range max....
And a torque monster
Starting with the block - Dart Big M Short or tall deck??
Maybe large Oval port heads.....?
Looking for some imput on this.....
XCAV8 is offline
Old 09-09-2003 | 08:50 AM
cougarman's Avatar
Default .
Check your PM.
Cougarman
cougarman is offline
Old 09-09-2003 | 08:02 PM
XCAV8's Avatar
I know i know, been here done that.....
You engine guru's don't want to give away the secrets..
just wanted a few opinions
on specific parts
dart big m ? tall or short deck?
rotating assembly ??
longer rods = better geometry ??
pistons?
Heads ?
cubic inches 540, 565, 572 ???
remembering i'm looking for mild bullet proof engines
XCAV8 is offline
Old 09-10-2003 | 12:34 AM
Bulldog's Avatar
See this thread- notably Kaama's results:
http://www.offshoreonly.com/forums/s...threadid=58079
I would go tall deck if you dont have stuff you need to re-use. Most parts cost the same either way, and in theory there are some slight performance advantages- also wear advantages. Less side thrust on the piston may result in better ring sealing, and piston skirt wear.
Bulldog- the 540 kind
Bulldog is offline
chromecat
19
10-26-2011 04:55 PM
Cat-n-Around
8
02-23-2007 09:31 PM
X-Rated30
08-23-2002 01:55 AM
dean campbell
05-31-2002 01:21 PM
