Blowing outdrives - Why??? >
Old 09-14-2003 | 01:25 PM
check300,
there you go. you should be able to figure out the problem with what check said.
bottom line is your boat is to heavey. you are pushing to much weight. a 24 eliminater cat wieghs a 1/4 of a 30 sonic. do all you want. you will always blow drives. all the money you spent on drives could of gone to a set of speedmaster threea's. and you would of still had some money in the bank. and if you don't want the transmision then use a crash box.
Treadwell
Treadwellmotorsports is offline
Old 09-14-2003 | 02:09 PM
mr treadwell a rookie question what the heck is a crashbox?
carreraboat is offline
Old 09-15-2003 | 01:43 AM
The lowers!? Very interesting...I'll let you know what I find out.
Back4More is offline
Old 09-15-2003 | 07:22 AM
Carreraboat:
A crashbox is a type of tranmission that is unable to shift under power, i.e. the engine must be shut off when shifting. A crashbox is simpler and stronger than a "normal" transmission.
vtec
vtec is offline
Old 09-15-2003 | 09:54 PM
thanks vtec but why the name
Old 09-15-2003 | 10:00 PM
1_bigdogg
My personal opinion why its called a crashbox.....cause when you are comming up to the dock and you can't get the dang thing into the gear you need ......well the rest is self explanitory. You see .....these are not the most user friendly of trannys.
Old 09-16-2003 | 07:56 PM
thanks big dog makes since
StraightJacket
Northern Illinois Offshore Club
11
10-28-2006 07:14 AM
86formula242ls
05-24-2006 08:43 PM
ripley
33
06-19-2005 11:07 AM
ArtsWarlock
13
11-05-2002 07:03 AM
