Bigger Power >
Bigger Power
Bigger Power
Old 09-13-2003 | 07:43 PM
dlbCheckmate's Avatar
Question Bigger Power
What are the pro's and con's ( power aside) of going with a 540 vs 572. Is there any advantages with the tall deck vs standard. Any block issues with going that big. How about some opinions ?
dlbCheckmate is offline
Old 09-14-2003 | 02:30 PM
What no opinions ? Maybe I should ask a cam question ?
Old 09-14-2003 | 07:44 PM
I am getting ready to build a 598 solid roller NA for my next project. Like any motor if it is built right it will deliver many hours of trouble free horsepower. How many hrs.? My motor will probably see new lifters and springs every 2 seasons or 50 hrs, whichever comes first and a complete going through at 200 hrs. For me that may very well be 5 or more seasons. The biggest downside to the larger motors is the fact that many short deck parts will not work. Things like the oil pan, distributor, intake manifold are to name a few. Hopefully more people will post their opinions, but as far as I am concerned go BIG!!!!
Craig
WETTE VETTE is offline
Old 09-16-2003 | 11:07 AM
Doesn't anbody have Tall Decks?
Old 09-16-2003 | 01:24 PM
TopSpin80's Avatar
572 is a square motor... 4.5bore, 4.5stroke.... these combinations of so called "square motors" are sometime said to be more reliable. It is only opinoin though I run a 540, and it lasts a whole season of extreme torture before rebuilds. I tear in down in the winter and go through it. A 572 could have more touque potential if built right. Hp doesn't make much difference.
TopSpin80 is offline
Old 09-16-2003 | 03:39 PM
I understand how the intake and the distributor would be a different size, what is the difference in the oil pans?
Woody is offline
Old 09-16-2003 | 04:19 PM
Stroke clearance!! Most pans will clear a 4.25" stroke max.
Old 09-16-2003 | 06:59 PM
mcollinstn's Avatar
Tall deck lets you run a more favorable rod length/stroke ratio. Generally speaking, a longer rod will reduce piston side loading in the bore and will transmit more power into the crankshaft.
mcollinstn is offline
Old 09-18-2003 | 11:53 AM
Thanks Guys, Wette Vette what specks are you considering ? PM me or post them, I'd like to compare. Thanks
Brian C
Donzi
3
08-27-2007 09:55 AM
Maximus_45
08-26-2005 01:55 PM
Dano
Sonic
4
01-18-2004 11:22 AM
GO4BROKE
Sonic
12
08-15-2003 11:21 AM
BruceK
Sunsation
3
05-14-2002 08:59 AM
