Whats the best cam for my engines?
Crazy,....do you mean cam lifters and springs?....I have new double roller timimg chain sets on it now......yes run it across the desk top dyno....not sure if it is +.030 or +.060 over lets fig. +.030 Edelbrock air gap RPM intake with 750cfm Demon carb...crap exhaust system....8.8:1 compression....rec. heads....what else?.....are you sure those cams aren't on 112 LSA?, thats what my parts rep. told me....Fred
I'll look again when I get home. I could be wrong. and if you don't need the timing chains the cost of the springs is just about a wash. You really need to check your springs to see if they're usable. If I remember right the FM springs for those cams are 115 lbs. on the seat. I'll double-check that too. Call me at home sometime after 3:30 today. By the way, today is Friday. Just in case you forgot,,,,,,
that's pretty common. at least around here it seems to be. I think springs are about 52 a set. I just looked and the springs are [email protected] inches, [email protected] inches.
Originally posted by fred
Crazy...I am getting prices from my guy now...then I'll try your guy...
Dennis, the cam that I took out was similar to the comp one you recommend, specsare;
Lift @ valve in. 530
" " " ex. 551
Duration, in. 228 ex. 236
spring press. if they used the #99893
closed 120# open320#
timing @ .005 in open 35 btdc closes 83 abdc
298 advertised duration
ex. opens 87 bbdc closes 39 atdc 306 ad. duration
cam timing @ .050 in 5 btdc 43 abdc 109 lift
ex. 57 bbdc (1) btdc 119 lift
114 LSA
Crane cam part #132561
look on www.cranecams.com for spec card.....Fred
" " " ex. 551
114 LSA
Crane also makes nearly the identical cam #134241 with a 112 lobe sep.
The rest of the #'s are very close.
226/236 and .534/.553 on a 112 lobe sep.
I used this cam in the 454 mag in Baja and it has a slight lopey idle and pulls strong to 5500 rpms. Just ask Outlawcowgirl, she owns the boat now.
Also, its half the price of the Merc replacement. It was about a $140 in the kit form (part #134242) from Summit Racing. The kit includess the cam, lifters, lube and lock plate.
Just saw that you said you had stock Merc exhaust.
I would be carefull going with anything less than a 114 with stock exhaust. I had Imco's so I don't know if it would revert with stock exhaust.
As I understand it Fred, yes. But the horsepower gains from running a 110 cam vs. a 114 cam in a naturally aspirated engine is noticable. You still thinking of adding blowers in the future? If so, staying with a 114 cam will be the way to go.
Crazy,....try running the Comp Cams grind #XM270H or part #11-236-4 cam on your desktop dyno, Thanks Fred
advertised in. 270 ex.286
at .050 in.226 ex.236
valve lift in. .544 ex. .547
112* LSA
112* LSA
