Electric fuel pressure >
Old 09-23-2003 | 04:23 PM
Jersey Tom's Avatar
Unhappy Electric fuel pressure
I just lost a motor when it leaned out due to a fuel blockage. I am looking to install fuel pressure gauges at the helm so I can monitor the pressure when driving. I don't want a repeat preformance. I want to use electric gauges rather than mechanical for obvious reasons. I can't seem to find any that are reasonable. The only setup I found was over $500 for two gauges. Any suggestions? This is for my cruiser not my Concept.
Jersey Tom is offline
Old 09-23-2003 | 06:16 PM
paradigm shift's Avatar
Gauges are great but depending on where the blockage was why not run low pressure cut out switchs? Cheap and easy. Sometimes I do not look at gauges all the time!!!! Like running WOT .
paradigm shift is offline
Old 09-23-2003 | 09:11 PM
mopower's Avatar
Toxic FORMULA
PS is right. I have fuel pressure gauges and rarely look at them over 60 mph. Normal cruise of 50 @ 3000 rpm, no problem. Anything over 60 where I boat , you have to be real sharp to avoid debris .
BTW , mine a Faria electrics and they were well below $500 , and are guaranteed as long as you own the boat
mopower is offline
Old 09-24-2003 | 08:57 AM
mcollinstn's Avatar
warning horn.
mcollinstn is offline
Old 09-24-2003 | 12:00 PM
mats's Avatar
You can buy them at cpperformance.com for some $80 a piece including sender
mats is offline
Old 09-24-2003 | 08:25 PM
Jersey Tom's Avatar
Thanks guys. This is only for my cruiser not my performance boat. It tops out at a blinding 25 mph. Plenty of time to look at gauges. I also want a gauge rather than a shut off or buzzer as I am still not sure that I have fixed the problem and want to use the pressure gauge to diagnose the problem, or lack of it. I have found a pair electric Gaffrig gauges and senders for around $170. I just want to monitor the new motor to make sure that the pressure is ok and hopefully not melt down more pistons.
Old 09-25-2003 | 10:11 AM
robyw1's Avatar
You can check some of these from www.autometer.com
Roby
2-5/8" Full Sweep Electric Fuel Pressure Gauges 3561
Sport-Comp Fuel Pressure Gauge 0-15 psi (Black Dial, Silver Bezel)
3562
Sport-Comp Hi-Lo Fuel Pressure Gauge 0-15 psi (Black Dial, Silver Bezel)
3563
Sport-Comp Fuel Pressure Gauge 0-100 psi (Black Dial, Silver Bezel)
4461
Ultra-Lite Fuel Pressure Gauge 0-15 psi (Silver Dial & Bezel)
4463
Ultra-Lite Fuel Pressure Gauge with Isolator 0-100 psi (Silver Dial & Bezel)
4863
Carbon Fiber Fuel Pressure Gauge 0-100 psi (Carbon Fiber Dial, Silver Bezel)
5461
Pro-Comp Fuel Pressure Gauge 0-15 psi (Black Dial, Silver Bezel)
5462
Pro-Comp Hi-Lo Fuel Pressure Gauge 0-15 psi (Black Dial, Silver Bezel)
5863
Phantom Fuel Pressure Gauge 0-100 psi (White Dial, Black Bezel)
robyw1 is offline
Rage
0
05-06-2008 11:00 AM
Rocko C
2
07-27-2007 09:26 AM
Noise Pollution
21
06-11-2007 10:09 AM
klaw
3
08-17-2004 01:04 PM
BAD-HABIT
9
05-06-2003 03:08 PM
