Any tips on doing engine alignments? >
Old 09-29-2003 | 12:32 PM
GO4BROKE's Avatar
Default Any tips on doing engine alignments?
I usually lift the engine with a chain fault to make an adjustment, then set it down and check it. After repeating this step 8 or 900 times I get it done. Anyone have any short cuts or tips?
[img][/img]
GO4BROKE is offline
Old 09-29-2003 | 12:57 PM
formula31's Avatar
For Bravo's I use an aluminum shaft turned to the coupler bore ID, usually around 1". This allows me to visually see where I have to move the engine. I can get pretty close before actually using the final alignment tool. Also, dont forget to rotate the engine 180 degrees and check it again. The coupler is not always centered on the flywheel.
formula31 is offline
Old 09-29-2003 | 01:47 PM
I use an old driveshaft with a pipe welded on the end.
Adjust up till it binds. Count turns and adjust down till it binds. Final adjustment half way in between
RickR is offline
Old 09-29-2003 | 03:11 PM
Caincando1's Avatar
Patience!!! ane a lot of it.
Caincando1 is offline
Old 09-29-2003 | 05:11 PM
Krumbsnatcher's Avatar
I just finished mine, the previous one was off by 3/8".
I used a cherry picker to hoist the rear of the engine after i loosed the motor mounts. I had to shim my rear until the alignment tool slid in nice and easy. after you tighten it down you have to recheck for alignment.
Buy the tool from mercstuff.com. Nice and easy with no splines. You just coat the tools with spline grease and insert you can see high and low spots so you can make adjustments.
good luck.
Krumbsnatcher is offline
Old 09-29-2003 | 05:59 PM
GO4BROKE's Avatar
I have the merc tool. I was just wondering if there were any methods the pros use to make the job easier. It always seems to be a project!
[img][/img]
GO4BROKE is offline
Old 09-29-2003 | 07:54 PM
Waterfoul's Avatar
Gone Fishin'
Put a dab of grease on the end of the tool. When you insert it, do it slowly until it hits the coupler.... then draw it back out slowly... you'll be able to tell from the wear on the grease which way you need to go.
Tinkerboater and I use this method whenever we do an alignment...and we do a lot of them because I'm always taking my motor out!! It really helps to have two people.
Waterfoul is offline
Old 09-30-2003 | 10:54 AM
Waterfouls method is the way that I see the mechanics at the marina I go to do it.....Fred
fred is offline
26sonic
08-06-2015 03:44 AM
bolgna
4
01-23-2008 06:23 PM
rangerrick63
01-02-2007 10:50 AM
Ted G
03-01-2006 11:10 PM
Raypanic
Powerquest
4
04-12-2002 09:07 AM
