rotating assembly balancing >
Old 01-09-2002 | 06:48 PM
traviss's Avatar
Post rotating assembly balancing
I am going to to have my rotating 383 assembly internaly balanced. So what flywheel and balancer will I need?
Can I use the stock merc flywheel?
or both flywheel and balancer need to be neutral balanced?
help.... the best engine machinest in town died last week he use to have all the anwsers..
[ 01-09-2002: Message edited by: traviss ]
traviss is offline
Old 01-09-2002 | 07:53 PM
Crazyhorse's Avatar
Post
The balance job will include getting the balancer and the flywheel balanced to neutral if you have the crank internally balanced. But the answer to your question is (assuming the flywheel and balancer were from a 350) yes you can use them. 350s, 396s and 427s are internally balanced, 400 small-blocks and 454-502 motors are not. If you're having a local shop do it expect to give the shop the crank, rods with the rod bolts you will be using in the motor, pistons/pins (and spiralocks if they are full-floaters), rings for one piston, bearings for one rod, crank timing gear, balancer, flywheel with bolts. some shops will ask for the coupler too.
[ 01-09-2002: Message edited by: Crazyhorse ]
Crazyhorse is offline
Old 01-09-2002 | 09:10 PM
traviss's Avatar
Post
thanks crazy exactly what i needed to know
traviss is offline
Old 01-11-2002 | 11:04 PM
Crazyhorse's Avatar
Post
No problem bud.
Cmoney
21
01-31-2009 11:19 AM
BobbyB
11
01-30-2009 12:35 PM
racinfever
Wanted
7
01-30-2009 12:03 PM
1BIGJIM
14
11-18-2006 04:41 AM
bn
Sonic
10
01-08-2004 07:11 PM
