pushrod problem + cylinder head bolt problem >
Old 12-01-2003 | 01:22 PM
timucin's Avatar
pushrods;
my calculations says;
intake 7.800
exhaust 8.600
does it sound resonable?
timucin is offline
Old 12-01-2003 | 02:42 PM
TURB02256
How did you arive at the calculation. I do mine using a checker push rods and machinest blueing on the valve tip. Then roll the cam around a few times to check the contact patch. also i check the lift on each valve with and with out valve lash before and after I replace the checker push rods with the new ones
Old 12-01-2003 | 03:05 PM
I to am showing world part #073010 for the eight bolts and Manley part #42102 for the washers.To check my geometry I got the plastic gage that manley makes at the speed shop that slips over the rocker stud and you use a feeler gage to check the difference and all seemed to work out well for me.
FloridianSon is offline
Old 12-01-2003 | 03:15 PM
timucin's Avatar
turbo2256; i also ordered pushrod length checker but , it came wrong
i cut and rebuild one for myself, then did the same things like you did and here is the results
-7,800 intake
-8,600 exhaust
but i cant find these sizes...
i finnaly spoked to crane cams after 19 minutes of call waiting they say that they have to custom build .....
timucin is offline
Old 12-01-2003 | 03:18 PM
timucin's Avatar
cylinder head bolts:
first arp package was wrong
second i ordered with the number is wrong
now will order the third.....
today is not my day.....
timucin is offline
Old 12-01-2003 | 03:20 PM
Did you try www.manleyperformance.com sight to see what they offered on the push rods?
Old 12-01-2003 | 04:01 PM
timucin's Avatar
nope
thnx for the link
timucin is offline
Old 12-01-2003 | 04:27 PM
timucin's Avatar
Floridian;
i talked & ordered from manley
thnx too much for the link
timucin is offline
Old 12-02-2003 | 01:03 PM
timucin's Avatar
http://www.worldcastings.com/tech/me...ylindehead.doc
here is the link it says use arp-135-3603 bolt kit, i already have but they dont fit?!?!?
my engine is mark IV,yep i am very sure cause checked the casting number etc.
yep my heads are merlin,it writes on them, part number etc,is ok
what does this mean?!?
strange isnt it?
timucin is offline
Old 12-02-2003 | 07:07 PM
Panther's Avatar
Frank's Marine Service
I ordered ARP headbolts recently and had to add an extra washer underneath the headbolt's to make it work. I have a mark VI block and the bolts were running all the way to the end of the hole. i wound up cutting an 1/8" off the threads and re-tapping the end. It all worked out fine after that.
Panther is offline
