houston prop >
houston prop
houston prop
Old 11-08-2003 | 08:55 AM
HOUSTONPROP's Avatar
Default imongo
are they satin finish or polished ?
HOUSTONPROP is offline
Old 11-08-2003 | 09:01 AM
crmax's Avatar
got a question I have a labbed 23 mirage plus Im hitting the rev limiter and need more stern lift my top mph was only hit with a full tank of gas and trimmed all the way up (20' wellcraft excalibur) . whats a good 4 blade prop and size? Im going to have it labbed,
crmax is offline
Old 11-08-2003 | 09:07 AM
imongo's Avatar
Polished...
Mongo
imongo is offline
Old 11-08-2003 | 09:33 AM
Default polished props rusting
not sure imingo,I suppose you could have them chrome plated? or a smooth power coating applied which is pretty neat and you can get different textures.
super smooth,semi rough,ect, different colors
not sure what to tell you,we could polish them with our process which is a lot different than the factorys electro polish (machine) I bet ours would last a long time if they were wiped down after each use.
Old 11-08-2003 | 09:36 AM
Default stern lift or bow
I know you said stern,but a 4 bld will slow you down ,get the 3 bld dialed in right and ride on the prop with more top end speed ,
although it just depends on the type of ride you are looking for ,
Old 11-08-2003 | 09:53 AM
Default Re: stern lift or bow
also the bravo one 4 bld is a good and very popular prop. maybe a 24 would be a good choice if it was labbed .
Old 11-08-2003 | 12:08 PM
imongo's Avatar
Thanks Darin!
What about some sort of epoxy paint?
Mongo
imongo is offline
Old 11-08-2003 | 02:08 PM
Default paint on props
nope,it will not stay on.
omc uses Teflon on some of there props and it stays on great, not sure how you could do that as I am sure there is a baking process.
I guess you could hit them with a scotch-brite pad when they start to rust ,and keep them wiped down with wd-40,just A idea.
Old 11-08-2003 | 02:59 PM
imongo's Avatar
Thanks again!
I guess powder coating is going to be the answer. I was hoping you had a magic answer.
Mongo
imongo is offline
Old 11-09-2003 | 05:36 AM
Default powder coating
imngo,The guy that bought my old company is now into powder coatings,he can do this and if you want I will ask him,I bet it would have to be white though as this is the only color he uses Darin
