Questions On Extension Boxes >
Old 11-29-2003 | 02:15 PM
GLENNS's Avatar
Default Questions On Extension Boxes
ARE THERE ANY GENERAL RULE OF THUMBS IF EXTENSION BOXES WILL BE OF BENEFIT TO YOU? DO THEY WORK AS WELL ON CONVENTIONAL V 'S AS STEP BOTTOMS? ARE THERE ANY DIFFERENCES PERFORMANCE WISE BETWEEN STELLINGS AND IMCO BOXES? THINKING ABOUT PUTTING BOXES ON A SLINGHOT ANYONE TRIED IT? THANKS FOR ANY INFO!
GLENNS is offline
Old 12-01-2003 | 08:57 PM
propwash's Avatar
Good question Glenns. I have wondered the same thing. Has any body used the drive boxes on a Formula F357 or F311, and what kind of luck did you have? Propwash...
propwash is offline
Old 12-01-2003 | 10:38 PM
puder's Avatar
speel chekk this fokker!
a standoff box put teh prop further back and into cleaner water but its effectively lowers your x dim.
Most people eitehr run a plus height box or a standard height box with shorty lowers.
ou get improved handling plus potentially raised xdims
Pardon me, while I whip this out!
puder is offline
Old 12-02-2003 | 01:05 AM
Good Question. I haven't been convinced yet of the theory that it always moves it into cleaner water as I have been fighting high propeller slip numbers with an ITS on a step bottom. I have been thinking that it may have moved it into more aerated water from the steps.
zahndok is offline
Old 12-02-2003 | 01:32 AM
puder's Avatar
very possible. I know boat run like crap with them.
I heard the single engine (25' i think) AT runs like crap with a standoff. Like handling issues and speed loss.
so no standoff boxxes aren't beneficially on every setup. Best bet is to contact themanufacturer and se ei fthey have any additional setup info.
puder is offline
Old 12-02-2003 | 05:01 AM
H2Xmark's Avatar
a friend of mine put the stellings boxes on a older 32 active thunder and picked up 4 mph
H2Xmark is offline
Old 12-02-2003 | 12:13 PM
GLENNS's Avatar
I THINK THAT IS WHAT I MAY DO IS CONTACT HUSTLER TO SEE WHAT KIND OF INFO THEY CAN GIVE ME. I JUST THOUGHT SOMEONE OUT THERE PROBABLY HAD TRIED THIS SETUP ON A SLINGSHOT OR SIMILIAR HULL STYLE. THANKS FOR ALL YOUR IMPUT SO FAR PUDER, H2mark, and ZAHNDOK. IF I GET ANY INFO THAT WILL HELP WILL BE SURE TO POST. THANKS
GLENNS is offline
Old 12-02-2003 | 12:55 PM
puder's Avatar
sweet let us know if it works and you pick up speed!
puder is offline
Old 12-02-2003 | 06:12 PM
H2Xmark's Avatar
let us know, good luck
H2Xmark is offline
DMOORE
Drives and Lower Units
4
03-23-2008 10:37 PM
fastmcars
7
11-12-2007 02:41 PM
Wild
Cigarette
2
10-03-2005 05:43 PM
bezdikjack
1
07-30-2005 10:32 PM
baja john
Baja
11
04-04-2003 06:56 AM
