three washers needed for head bolts!?! >
Old 12-05-2003 | 05:26 PM
rmbuilder's Avatar
MarineKinetics
More information. Also you may want to use a stud kit as an option.
From World Products
http://www.worldcastings.com/tech/me...ylindehead.doc
http://www.theengineshop.com/content/pg35.pdf
From ARP
Bolts
http://www.arp-bolts.com/media/pdf_files/headbolts.pdf
Studs
http://www.arp-bolts.com/media/pdf_files/headstuds.pdf
Bob
rmbuilder is offline
Old 12-05-2003 | 05:55 PM
timucin's Avatar
rm
i already checked those www's.
ordering the parts with thier part number but however they dont fit.
thnx for help
timucin is offline
Old 12-05-2003 | 05:59 PM
timucin's Avatar
+i also did everything which is mentioned on the tec-tips
-cleaned the block 4-5 times (bolt holes)
-used some motor oil for easier turn
etc-etc
timucin is offline
Old 12-06-2003 | 09:53 AM
timucin's Avatar
i agree with you formula, now as i mentioned will receive another package next week but this time they have all necessary lengths for each bolt (3 diferent size required)
we'll see....
by the way what do you call the turns on the bolt?
timucin is offline
Old 12-06-2003 | 10:49 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
My suggestion of cutting the bolt shorter was solely dependent upon the length of available threads. But from his reply, I take it they start below the head/block surface, at which point I agree it is best to wait for the next order try. IF the threads would have extended into the head, cutting the bolts to correct length would have been ok. I was under the impression that the MK4 454's had thru holes?
The turns are called threads.
Want all the info on bolts? such as pitch, tpi, major and minor dia's, pitch dia's, grade, classes, and tons more terms that describe the threads. And I bet you thought a bolt was just a fine or coarse thread.
Post the results for next weeks purchase try.
US1 Fountain is offline
Old 12-06-2003 | 02:58 PM
timucin's Avatar
-yes pls
-ok
timucin is offline
Old 12-07-2003 | 12:06 PM
Strip Poker 388's Avatar
Rob
A possibility ,Maybe the heads have been cut this much?????
Is all the thread on the stud going into the block??
Strip Poker 388 is offline
Old 12-07-2003 | 12:11 PM
Sorry you are having so much trouble.On my newer merlins they have the 4 head bolts that are above the exhaust port raised so I needed a 5" long bolt when the washer was installed,is it the same on your heads.I ordered the bolts from World and the washers were a manley product.On mine the stock head bolt measures 4" long and that is with the built in shoulder.The ARP bolts that I have measures 4" with there washer installed.Do you know what size bolt you need I have plenty of ARP sitting around.
FloridianSon is offline
Old 12-07-2003 | 01:57 PM
Panther's Avatar
Frank's Marine Service
Timucin,
Do you have and stock head bolts laying around to see how they fit? I have a brand new take off set of headbolts for a mark 6 if anyone wants them.
I got a brand new GM motor over the summer and it cam with stock heads. I removed the heads, put on the Merlins, put in my cam and was ready to rock and roll.
If anyone wants the bolts email [email protected]. I will sell for $25 plus shipping.
Panther.
Panther is offline
Old 12-07-2003 | 03:00 PM
timucin's Avatar
thnx for all help;
i dont remember the spesific measures of the bolts.papers are not with me.
i tink so but dont remember now,
will post all tomorrow
timucin is offline
