Acclerator Prop Delivers >
Old 03-28-2004 | 06:01 AM
  #51
HOUSTONPROP's Avatar
Default SPARE ALUMINUM
PROPS ON SALE NEW 95.00
HOUSTONPROP is offline
Old 03-28-2004 | 12:11 PM
  #52
Plum_Crazy's Avatar
Can someone please post before and after results from their Accelerator prop? So far the only delivery I've seen is by UPS.
Plum_Crazy is offline
Old 03-28-2004 | 02:02 PM
  #53
Try this
http://pub47.ezboard.com/fteambajama...icID=415.topic
Preuni is offline
Old 03-28-2004 | 03:30 PM
  #54
Darin are yoiur props datalogged into a computer? I was just wondering how you guys get all of the blades identical. Thanks greg
HPJunkie is offline
Old 03-28-2004 | 07:56 PM
  #55
Ric232
A computer is no match for Darin's "lucky finger" !!
Old 03-29-2004 | 09:53 AM
  #56
markt111's Avatar
Darin I am buying a new boat and it has "Mach Stern Driver" props on it, I have never heard of these, they are 22x14.5 4-blades, thay are on a 30' scarab center console with twin johnson 250s , are these a good prop? what prop would work the best on this hull? am I loosing speed with 4-blade props?
markt111 is offline
Old 03-29-2004 | 11:39 AM
  #57
Default Mach props
are the props turning in the rpm range of the motors??
Johnson only built a v-6 250 outboard in 98 and all the others are v-8 outboards you should be spinning around 5,800 max rpm.four blades always run a little slower but you may need them on your set-up.Handling is alot better with four blades especially in rough water ,Mach props are ok.they are weld on blades and I have seen several sets where the blades are not set all the same ,The omc offshore series four blade Renegade would be your best all around prop.give me a call and we can talk more about what you have .Thanks Darin
Old 03-30-2004 | 07:14 AM
  #58
markt111's Avatar
the motors turn around 5500 RPM, the motors are 1994s with low hours and run great, so what type of improvement would I see with OMC renegades? is it a noticeable improvement?
markt111 is offline
Old 03-30-2004 | 08:13 AM
  #59
dyno's Avatar
Charter Member #655
Darin can you make Accelerators out of standard Mirage solid hubs?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-30-2004 | 04:36 PM
  #60
Default Mirage or Mirage Plus
yes,we can do the ACCLETRATOR design on either.
