ACCLERATOR PROP, RESPONDES QUICK
1 Attachment(s)
EXCELLENT TOP END,MIDRANGE IS UNBELIVABLE,NO BLOW OUT TURNING,EXCELLENT BOW LIFT FOR REDUCED DRAG.PLANES OUT VERY QUICK.
How much for a 27 LH. I was looking for a 27 mirage plus. Would you recommend the Accelerator over mirage plus for a single engine V looking for more bow lift. Running a 26 bravo 1 at 5600 now. Thanks. You will get a lab job what ever I end up with. :D :D At least that is the plan.
I have run smaller 3 blades and like the way the boat handles slightly better than with 4 blades. Just guessing on 3 blade pitch. I have a 28 bravo 1 and it works well but I would like a few more RPM and more bow lift. Runs about 5100 - 5200. |
Mirage conversion to
THE ACCLERATOR PROP DESIGN.
YOU bet this is the ticket,you could probably pickup up a Mirage plus LEFT HAND DIRT CHEAP ON E- BAY.. THATS YOUR BEST WAY TO GO probably a 100.00 or so and then we can convert it to the ACCLERATOR,Make sure it's a PLUS . We are making some great deals right now,we appreciate your Business. dealer cost on a Mirage is 369.00 no big secret,but being a left hand YOU CAN GET ONE CHEAP OR I,WILL DO IT FOR YOU.I have a 17 new mirage plus on e-bay starting at 25>dollars:rolleyes: and still cant give it AWAY.:confused: GIVE ME A CALL /when your ready/ now is the time for a good deal on ALL PROP MODIFICATIONS. |
Darin
I have two props comming your way. |
27 left mirage plus 99.00 e/bay
there is a 27 Mirage plus on there right now with 11 hours left for 99.00 no current bids and the time is
4:o4 central time , YOU BETTER HURRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!! YOU BETTER HURRY!!!!!!!!!!!!!!!!!!!!:D :D :eek: :eek: :eek: 27 LEFT mirage pluus on e-bay 99.00 hurry hurry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Is this a Mirage that you are cutting down?
there is alot more to it than the eye can see.
Jim V race boat prop
Jim ,We are working on the new prop that you ordered .FOR THE RACE BOAT.
And, I will call you when the other two arrive,Thanks again for the work,Darin |
Houston Prop,
You guys sure have an awesome reputation on OSO. I have tried the Mirage's, and Spinelli's, now have 28 Hydros, good top end, but terrible blow out, sometimes can't plane regardless of method used (in rough water). Boat, Cig 30 Mystique (non stepped) 500 e.f.i.s, turning bravo's 1.5 @ 5050/5100, 82.1 G.P.S. Hydromotive recommends the flared rim extension, BUT says a speed loss is imminent. Should I try to find 30 mirage's, and have you perform the "accelrator" mod or what? I have seen the similar treads regarding this blowout, however not concluded a recommendation. Do you buy fast props, then install the rings to slow back down? Thanks. |
CIG/30
Thanks for the compliments, Have you tried BRAVO-ONE FOUR BLADE PROPS AT ALL??
I think a set of 30 highly labbed Bravo -ones with exhaust flange's cut back and tuned to your boat would be the best setup. we do buy props, but not at this time of the year,we can work your hydros to reduce the blowout tremondusly. 3 blade props no what? are not the answer on your setup. |
Re: 27 left mirage plus 99.00 e/bay
Originally posted by HOUSTONPROP there is a 27 Mirage plus on there right now with 11 hours left for 99.00 no current bids and the time is 4:o4 central time , YOU BETTER HURRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!! YOU BETTER HURRY!!!!!!!!!!!!!!!!!!!!:D :D :eek: :eek: :eek: 27 LEFT mirage pluus on e-bay 99.00 hurry hurry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! One question and maybe a dumb one at that. Being that all props are different should I run this 27 mirage plus to get some base line numbers before we look at reworking it. Probably January or February before I can get that opportunity. :mad: |
27 lefty
Thats good that you got the prop you needed.
call me when you get the prop and we can talk about it . later, Darin:D |
Thanks for the reply. Sorry about the misunderstanding regarding the remark "do you buy fast props, and install rings to slow back down" I was referring to me and the others that have changed props, only to later have to install these "rings". and then be back where we started. Also I stand corrected, the boat had Bravo props, (not labbed) not Mirage's. If you were to rework the Hydro's, you indicate the "blowout" would be improved, however would there be a loss of top spreed? I realize there are no guarantee's, obliviously your word and best intentions are just as valuable.
Thanks |
Cig 30
no problem,as far as loss of speed ????
the honest answer is I do not know for sure . it could run faster,may run slower? but would surley plane out quick ,with little blowout, I am pretty sure what needs to be done in my mind:rolleyes: :D what to do to make them plane quick and keep the rpm and speed up.(Thats the GOAL.) if not we can always put them back where they were,and try something else,you only pay -once at my shop. we will get it, until we hit the mark. what pitch B-1s did you have ? |
Man, would it be awesome if Cigarette was half as responsive as you guys (Houston Props). The B-1s were 30's. Can't ask anymore than you have offered. Will get the props off the boat (stored) and contact you direct.
Many thanks, what a pleasure! |
How many rpm's do you gain from a stock mirage plus 27 to the modified Accelerator treatment on the same prop?
Thanks, Chris |
IronMan
it just depends on what you need ??
more or less can be achieved ,but there is a maximum of 600rpm's each way.send me a pm and let me know what you are running ,where you are at for rpms and speed and what would you would like to achieve. Darin/:o talk to you tomorrow:o |
paradigm shift
did you recieve you new prop yet ,your 27 lefty?
also give me a call and we can get you 27 and your 28 dialed in .Darin |
HAPPY HOLIDAYS
TO ALL MY OSO FRIENDS.
Darin
can you make accellerators out of Quicksilvers (25") or would they be "trade ins" i have stock 330's on a formula 272. 4500-4600 64mph top speed/ I want same wot rpm, same cruise (40mph at 3000rpm) but top end gain is this the prop for this, or labbing and cupping my quicksilvers, or start over with something more modern thanks ramb |
Hey Rob, thanks for the post.
Inside joke for most of you. |
ACCLERATOR PROP
WATERFOUL,We CAN TAKE EITHER PROP THE ORIGINAL Mirage or the plus and make the modifacations to increase everything on all ends ,you will be greatly suprised of the results.
Give me a call when you can and we can talk futher or in more detail if you want to go faster:D :) Darin |
ALL NEW ACCLERATOR FOUR BLADE!DESIGNED BY,Houston PROP.
IT'S VERY MEAN LOOKING AS WELL, THE PERFORMACE IS GREAT!!!!!!!!! COMING SOON, ACCLERATOR FOUR BLADE. |
Darin i am turnning 5200 rpms with a 19" 3 blade SS prop on my 19' Donzi bowrider. it has a 4.3 V6 I need to upgrade to a 21" prop I was looking at the revolution 4 to keep some of my holeshot and I need a stern lifting prop not a bow lifitng prop like the mirage what prop do you think I should go with?
depends
on how much money you want to spend?
the rev four 17 PITCH stock would work great or a lab finished 19 rev four would work good . AT LEAST ON THE rev four I would try it before you buy one,and the others we sell have a 35>00 exchange policy. we have other brands that are available that might just be the ticket with -out having to do anything other than put it on and go. Give me a call when your ready .' Thanks for posting or asking,Darin M. I really need alot more info on your set-up to get you just the prop you want and need. |
darin i will give you a call when this spring after i get my winter projects done so we can disccuss it in detail and i can try a few different ones $35.00 is a great deal for me to try one out.
IF YOU CHOOSE ,THE PITCH
1 Attachment(s)
AND DON'T LIKE IT ,THEN THERE is a 35.oo swap charge for another new prop in a different pitch,if we recommend a pitch and happen to be wrong there is no-charge.
Hi Daren ! I received my prop from you today !! It looks great !!! Cant wait till spring to try it out !
Thanks for everything Den !!! |
dencam7
1 Attachment(s)
yours was the ACCLERATOR PROP, LIKE THIS ONE;)
Hey Darin, is that mine? :)
Roby |
HELLO ROBY,GET BACK TO WORK
YOURS will look like this one,sorry about you coming out the other day and it was not done,I thought it was done,its been very hetic around here ,props coming in faster than we can think:rolleyes: :D but believe me I am not complaining one bit,I will call you next week when yours is done probably towards the end of the week.;)
no problem, take some time to relax and have a good weekend,
Later Roby |
ROBY1 THANKS
1 Attachment(s)
SAME TO YOU, IT SURE IS FLYING BY,I will talk to you this week,Darin
737/300 COCKPIT:D |
ROBY1
Thanks ROBY1 for the Business,I am glad you like your new prop.
also, Thanks very much for your prompt payment. sold the old 21 to some guy in Kansas.:eek: :D stop by anytime/later Darin |
ACCLERATOR PROP IS ALL OVER
THANKS EVERYONE ,THIS NEW DESIGN is all over the country now from Canada to Germanay,Brazil,east coast to west coast,NORTH TO SOUTH.
Thanks again everyone.:D :) |
Darin, hope all is well. I have a west coast boat. Essex 29' @ 6,500 lbs running. HP500EFI Bravo 1, 1.50 & 22p bravo 1. The boat runs 60-61 @ 5000 rpm's. With a 24p it run's same top end @ 4700 rpm's. The boat comes on plane very good and runs hard up to about 50-55 mph & starts to hit the wall. Its takes very little + trim any more & it scrubs speed. Boat stays very flat coming on plane & to top speed. Would a 3 blade allow more bow lift to free up the hull. No steps in bottom, just about 8' notch in the delta pad.
Thanks, Mike |
cola6988
1 Attachment(s)
yes ,I have just the prop for you to get the boat up and out of the water and get a little more rpm which will give you alot more speed. give me a call when you can,Darin
ANDY FROM GERMANY
Thanks very much!
your prop will be shipped next week, towards the end of the week. Thanks again ANDY good TALKING TO YOU, Darin |
Hi Darin,
cant wait to try the prop, will post results, but I am sure I will see the 3mph gain all the other Baja boys saw on their rides..... BTW I think there was a little mixup regarding payment, I will pm you to clarify this. Andy |
the shipping to GERMANY WAS HIGH DOLLAR:eek: ;) P.M. ME AND LET ME KNOW WHATS UP,Darin
| All times are GMT -5. The time now is 10:29 PM. |
