exhaust shutters >
exhaust shutters
exhaust shutters
Old 12-09-2003 | 12:53 PM
ursus
Default exhaust shutters
I am reading merc service bulletin 2000-13 and see it recomends for 496/8.1 L engines:
For sterndrive packages using a through the prop exhaust system, do NOT use internal shutters, external flappers, or resonators.
These are the flapper things in the Y pipe to prevent water from rushing in when you back up. Any comments on whether they should be used on a 502 mag or not when running thru prop exhaust?
I noticed a piece of one when i pulled out this year in the water outlet at the base of the transom plate so I was gonna order them to replace in the spring but now I am wondering if I should just remove them.
Old 12-09-2003 | 03:23 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My 502's have the shutters in both the tail pipes and the y-pipe. They are in there for a reason, so if yours had it originally, I would replace them.
US1 Fountain is offline
Old 12-09-2003 | 08:57 PM
Tinkerer's Avatar
They won't last. ( the ones in the Y pipe that is )
Mine lasted about one hour ( I run my exhaust a little hot )
Tinkerer is offline
Old 12-10-2003 | 08:32 AM
ursus
Yeah thats the thing they never last more than 2 seasons if lucky and a lot of time barely 1 and now I see merc has an update in a service bulletin to not install them in 496's
trawfish
5
02-09-2008 09:09 PM
Rage
41
02-18-2007 09:42 PM
tomtbone1993
Fountain
29
05-24-2006 11:19 AM
wkd1
9
07-28-2005 10:41 AM
26sonic
01-29-2003 08:38 AM
