O-ring sealant on bravo 1 >
Old 01-28-2002 | 12:31 PM
blue thunder's Avatar
Talking O-ring sealant on bravo 1
What sealant works best on the o-rings when reassembling an outdrive. My Seloc manual says 3M sealant part number XXXX. What do you use, if anything.
BT
blue thunder is offline
Old 01-28-2002 | 03:02 PM
formula31's Avatar
Post
I'm not sure which ones you are talking about, but on the covers and the drive to bell housing I use contact cement to hold them in place and then liberally coat them with the blue/green gimbal bearing grease
formula31 is offline
Old 01-28-2002 | 03:09 PM
blown formula's Avatar
Post
Normally just use grease, but I just tried Goop marine silicone on the outdrive "elk horn" exhaust manifold o-ring. Sure hope it works!!
blown formula is offline
Old 01-28-2002 | 05:16 PM
traviss's Avatar
Post
I just slap some white lithum grease on the o-rings...
Travis
traviss is offline
Old 01-28-2002 | 06:52 PM
Post
Thanks guys. I had some green silicone looking crap all over them. Maybe that is why it was leaking. O rings shouldn't need anything (other than oil/grease) was my opinion, and evidently yours as well.
BT
Old 01-28-2002 | 06:58 PM
Post
Oh yeah... Formula31, the top of the back cover's o-ring had a white powdery type substance on it (efervesence?) so I believe that to be my water leak. Thanks for the advise. I think you were right on!
BT
Old 01-28-2002 | 08:03 PM
Cool
"Hylomar" it's a Permatex product that works great on O-rings and gaskets. I've even used it to repair a rusted/leaking manifold to riser joint.
RickR is offline
evaluex
4
07-10-2007 05:01 PM
nova
51
11-27-2006 06:04 AM
JimV
Prop Talk
12
10-25-2006 12:08 PM
Pantera1
9
07-06-2006 08:34 AM
Biggus
2
04-23-2002 10:28 AM
