Merc 575 540ci questions >
Old 12-30-2003 | 03:34 PM
Here is some more of what I had...
Back4More is offline
Old 12-31-2003 | 02:10 PM
Firewalker
http://www.cranecams.com/master/apps....%20Mechanical
That is the link for the cam part number
RT
Old 12-31-2003 | 02:53 PM
rmbuilder's Avatar
MarineKinetics
Thanks RT,
Bob
rmbuilder is offline
Old 12-31-2003 | 05:08 PM
ApachePete's Avatar
My first 41 Apache had those motors. Lot's of problems with broken rocker arms (bad batch from GM, they said). Burned some oil from the beginning, but no major problems once the rocker arms were replaced.
I had C&G rebuild them after the first summer to 650's (cam and heads). Then the transmissions had continuing problems (Speedmaster 3's).
ApachePete is offline
Old 01-01-2004 | 12:02 PM
KAAMA's Avatar
Firewalker, here's something to consider...
Just remember that the Merc 540"/575hp engine has a mechanical cam as mentioned above----that means maintenance---periodic valve train adjustments. Which isn't always the best way to go these days. You could always add a hydaulic roller cam which will eliminate the need for pain in the arse valve train adjustments and be much better off-------that is of course unless you enjoy or DON'T mind doing maintenance on the valve train.
KAAMA is offline
Old 01-04-2004 | 05:42 PM
seabeach's Avatar
Have 2 of those in my boat, no problems after first season. I changed cam to a hydraulic roller, crane 139651 and it works great.
Some additional info:
Pistons, JE
Block, Bowtie
Crank, also Hank the Crank
Produced 1986-1992
If you want photos or any other info please mail me at [email protected]
Have a nice day!
/Torbjorn
seabeach is offline
Old 05-14-2007 | 11:21 AM
My friend just bought a Top Gun -87, the boat is in mint condition and havn´t been run the last 5-6 years. We fired the engines and everything spun well, but for now I woundering how long is the service interval for the vale train adjustment?
Luuk is offline
Old 05-12-2021 | 12:10 AM
Originally Posted by Biggus
Here a pic
Hi Biggus.
Do you have the pic in better quality please? Incl. Outdrives?
neuer_Typ is offline
dfealy
11
09-21-2007 04:07 AM
Wild
3
07-30-2007 02:55 PM
socalstone
Fountain
24
01-16-2007 10:50 AM
SuperiorOKC
01-12-2007 03:09 PM
Miller
01-21-2002 12:33 PM
