Stringer Replacement Formula 302 >
Old 01-04-2004 | 12:33 AM
Audiofn's Avatar
Charter Member #232
Then out came the floors. They were bonded to the stringers so I used a very large pry bar to get them to pup up. This is the foam that was under the floors and it reveales the stringers underneith.
Attached Thumbnails Stringer Replacement Formula 302-11-floor-lifted-up-small-.jpg
Put your best foot forward!
Audiofn is offline
Old 01-04-2004 | 12:34 AM
Audiofn's Avatar
Charter Member #232
Unfortunatly this is what I found. ROT
Attached Thumbnails Stringer Replacement Formula 302-12-rot-corners-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:35 AM
Audiofn's Avatar
Charter Member #232
More ROT This is the front of the stringer that goes along the side of the gas tank. As you can see if you look close they did not glass up and over the top of the bunkhead. This allowed the water to travel downt he bunkhead and cause all this trouble. Another 30 bucks in material and this would never have happened. Oh well.
Audiofn is offline
Old 01-04-2004 | 12:41 AM
Audiofn's Avatar
Charter Member #232
I then cut out all the foam that was btwn the two stringers.
Attached Thumbnails Stringer Replacement Formula 302-13-after-foam-removal-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:42 AM
Audiofn's Avatar
Charter Member #232
Another picture of the stringer damage
Audiofn is offline
Old 01-04-2004 | 12:45 AM
Audiofn's Avatar
Charter Member #232
I started to then take out the bulkheads going to the cabin. When this boat was built it was made with just plywood that was carpeted NOT glassed in. I am going to change that part of the design.
Attached Thumbnails Stringer Replacement Formula 302-16-start-bulkhead-removal-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:48 AM
Audiofn's Avatar
Charter Member #232
This is what I was working on tell I found the nightmare This is what all the wireing will look like when I am done. Now that the bulkhead is out I will have GREAT access to the dash to wire it up
Attached Thumbnails Stringer Replacement Formula 302-17-what-future-holds-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:49 AM
Audiofn's Avatar
Charter Member #232
How is this for a NIGHTMARE!!!! Had to take out the Fridge and the Microwave and a bunch of other stuff.
Attached Thumbnails Stringer Replacement Formula 302-18-what-mess-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:55 AM
Audiofn's Avatar
Charter Member #232
After I got half the bulkhead out I was able to pop out the tank
Attached Thumbnails Stringer Replacement Formula 302-19-gas-tank-out-small-.jpg
Audiofn is offline
Old 01-04-2004 | 12:57 AM
Audiofn's Avatar
Charter Member #232
And out comes the tank.
Attached Thumbnails Stringer Replacement Formula 302-20-gas-tank-out-small-.jpg
Audiofn is offline
