Timing gun in a 28 Cigarette >
Old 01-14-2004 | 06:14 PM
Default Timing gun in a 28 Cigarette
I have a 1985 28 SS with small blocks. I just replaced the heads on the port motor and after I put the distributor back in I realized I can't get to the harmonic balancer with a timing gun because it's way up underneath the back seat. Anyone who has seen the engine compartment in a Cigarette 28 SS with TRS drives knows what I'm talking about. So I'm curious, how do I set my timing? A friend of mine said sometimes theres an inspection hole in the back of the bellhousing so you could time it off the flywheel. Anyone ever heard of this? If so, where would it be? I looked and can't see anything obvious. I'd appriciate any help from anyone who has run into this type of problem.
Dave
Dangerous Dave is offline
Old 01-15-2004 | 06:22 AM
Offshore Addiction
yes,some of them have a hole on the portside top with a timing mark set up in them,if not I have used a small mechanics mirror and a timing light!
Old 01-15-2004 | 08:03 AM
Crazyhorse's Avatar
Yup, that hole on the top of the bell housing will be about 2 inches in diameter and have a rubber plug in it. If you've got it, that is.
Crazyhorse is offline
Joe
09-05-2007 08:35 AM
Magic34
09-18-2006 07:10 PM
Schweeng
04-03-2006 01:53 PM
RMPRam
12-20-2002 01:55 PM
