Valve cover breathers.. >
Old 02-05-2004 | 07:57 PM
Cignificant's Avatar
Default Valve cover breathers..
I've got oil constantly seeping out of the vents on my valve covers. They're Teagues, with the bolt on "stack" vents. Is there some type of fill-material I can install in the vents to capture the oil before it blows out? And where do I get it?
Thanks in advance!
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 02-05-2004 | 08:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Scotchbrite pads?
US1 Fountain is offline
Old 02-05-2004 | 08:10 PM
Is there a baffel inside the valve cover?
If not Moroso makes one.
RickR is offline
Old 02-05-2004 | 09:47 PM
ALFSTER's Avatar
Steve, I use sweat bands that you wear on your wrist,around the outside they work good,they keep the oil off the covers
ALFSTER is offline
Old 02-06-2004 | 07:22 AM
No baffles - they're hollow.
Sweat bands? I'm worried about heat. Maybe I'll stick a set if them and a scotchbrite pad in a 450 degree oven and see what happens. Probably do this sometime when the wife's not home..
Thanks for the suggestions.
Steve Gresham
'03 Donzi 33ZX
Old 02-06-2004 | 11:54 AM
OldSchool's Avatar
Steve,
What about something like this. Plumbed up into the Arrester.
OldSchool is offline
Old 02-06-2004 | 03:44 PM
Craig, neat arrangement. Looks like some custom machining/welding.
But I'm running short on time - too many projects left to get this thing back together!
Steve Gresham
'03 Donzi 33ZX
Old 02-06-2004 | 04:01 PM
AKA NoMoBoatin
sweatbands work a friend of mine uses the samething and it works.hey steve see you july 31 at jordan point.is there any motels close to there to stay friday night before the poker run.
docmanrich37 is offline
Old 02-07-2004 | 08:50 AM
There are a few hotels back up towards I95 on rt 10. I always send out a flyer to registrants a few weeks before the Poker Run giving details. The ph#s will be in the flyer.
Steve Gresham
'03 Donzi 33ZX
Old 02-07-2004 | 09:54 AM
tmdog's Avatar
Smile
I had the same problem and fixed it by adding a puke tank. Tank was made from a empty paint quart can. No more hoses to the flame arrester. Insert barb fittings in side of can w/ one fitting on top to vent fumes to outside thru hull fitting. I hope this helps. JIM
tmdog is offline
