Solenoid Dump Valves needed >
Old 02-11-2004 | 08:17 PM
Reed Jensen's Avatar
Default Re: Solenoid Dump Valves needed
Originally posted by blown formula
I am looking for some electric solenoid valves to be used as header water dump valves. Has anyone ever used something like this? If so, what is your source for the valves?
Any feedback- positive or negative is appreciated.
Are they water jacketed headers? Or wet headers where they are single walled and water is allowed to spray into the exhaust stream?
Reed Jensen is offline
Old 02-11-2004 | 09:49 PM
It sound like the 1/4" lines will drain when sitting not running and when running there will be some water coming out them. Probably such a small amount that it won't matter much. I like the idea and will put it on my boat.
cobra marty is offline
Old 02-11-2004 | 10:28 PM
blown formula's Avatar
These are "jacketed" Lightning headers, not water injected like a jet boat has.
This 1/4" line thing might also help relieve excessive water pressure that some people see at high rpm's....
it sounds like a sound theory to use and has practical usage behind it & it is easy to remove if there is a problem. Simple solution to a complex problem!!
blown formula is offline
Old 02-11-2004 | 10:42 PM
38KV's Avatar
DanB,
I was going to answer your question when cobra marty just did it for me.
You nailed it Marty!That is how it works.
One 1/4" per engine (use a Y or T pipe) doesn't affect the exhaust water flow or pressure at all.
Make sure to use good clamps and hoses and seal the water dump well to the transom.
Jonas.
38KV is offline
Old 02-11-2004 | 11:12 PM
38KV's Avatar
blown formula,
Now you can call the thread
"Solenoid Dump Valves Not Needed"
Let me know if your are happy when you have tried it.
Good luck!
Jonas.
38KV is offline
Old 10-11-2004 | 11:24 PM
We have now installed these 1/4" dumps on a Fountain and a Sonic... It works awesome!! Thanks for the tips 38KV!!
Old 10-12-2004 | 12:01 AM
38KV's Avatar
Glad I could help.
38KV is offline
spilman
0
01-21-2008 11:48 PM
tomcei
Pantera
3
07-28-2007 05:18 PM
jdub
6
04-13-2007 06:40 AM
Kidnova
10
09-06-2006 08:44 AM
Monty
8
02-24-2004 05:22 PM
