90 degree Sea Water pump
I have a pair of 502's with the sea water pumps and the fuel pumps integrated on the same pully. My current water pump outlet come out right into the motor mounts with little room for the hoses. Does anyone know if mercury still makes the pump housing that the outlet come out at 90 degrees. Where can you get them?
It is a 30' Spectre. It does have race mounts but I wasn't sure about putting holes through them? It had the hoses cramed in with a couple of elbows with hose being pinched under the motors. We were pulling the motor anyway but I think you would have had to pull the motor to change the impeller???
My buddy has an old pump housing with 90 degree screw in fittings but I haven't been able to find one?
BillR
11
07-29-2022 06:31 AM
