Best Oils
I suggest running 10-40 w oil... . Remember... multi viscosity oil stays the same thickness whether hot or cold... but the thinner the oil.. the better the flow... it doesn't matter how much pressure you have... if the oil isn't flowing.. you aren't lubricating... thinner oil passes through the filter easier with much less going around the filter through the bypass. Thinner oil also cools the engine better... the oil flows out past the edges of the rod bearings and flings up to the undersides of the pistons.. where it removes some of the heat from the piston... if the oil is thick.. it isn't flowing as much and removing the heat from the pistons. Hence.. more wear... more chance of detonation.. etc etc. Also ... thinner oil pumps better up the push rods and flows more oil over the valve springs to remove heat there.
Troutly,
I've been using Amsoil 15W-40 for some time now. At my next change, I'm going to switch to Amsoil Series 2000 20W-50 Severe Service Racing Oil. I think it's a little bit better (definitely more expensive at $8 vs $5 per qt), but it may be overkill.
I'm also using Amsoil Series 2000 75W-90 in the Bravo. It works great. Shifts much better than the Merc stuff.
Amsoil Marine and diesel in the engine and the PSD F350. Amsoil 2000 in the Bravo.
I put the amsoil in at the begining of the season last year. 1 drive had to be pulled to put a new shift cable on. The service center changed the oil to Merc hp. Later in the summer the clutch cones welded up in the drive with the Merc oil in it. I wonder if it would've happened if it had the Amsoil in it??? The other drive was perfect all summer.
