Which Amsoil Gear Lube to Use? >
Old 02-19-2004 | 08:02 PM
BAD-HABIT's Avatar
Default Which Amsoil Gear Lube to Use?
I noticed Amsoil shows two different types of 80w90 gear lube...A basic and a marine version....What is the difference and which lube does everyone use....
BH
http://amsoil.com/products/gearlubes/index.htm
BAD-HABIT is offline
Old 02-20-2004 | 12:26 PM
Ric232
I had the same question.
Actually, I use the Series 2000 75W/90 gear lube. It only comes in one version. I did quite a bit of research and decided that you should use either the Marine version of Amsoil's gear lube OR the Series 2000. I'm not sure what the difference is with the Marine (ALU) and non-marine (AGT), but it can't hurt to use the marine version. The key is (unless you are using Series 2000) to use the GL-4 lube. GL-5 lubes can contain sulphur-phosphorus additives to help them meet the more stringent GL-5 standard, but these additivies corrode yellow metals (like those in your outdrive).
However, from what I understand, Amoil's Series 2000 75W/90 gear lube (TGR) is 100% synthetic and therefore does not contain sulphur-phosphorus additivies. Note the label on the bottle says "100% synthetic" while the AGT and ALU labels do not say that. The TGR bottle also says that it is compatible with GL-4 and GL-5 applications. This is the best of both worlds because GL-5 is a better standard.
The same is true with Royal Purple in that they use a synthetic additive to meet the GL-5 standard. Here's more:
www.royalpurple.com/pdfsa/mgearaps.pdf
Anyway, I like the Series 2000. It is more expensive, but I think it is worth it.
Old 02-20-2004 | 01:37 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
SERIES 2000 75-90
WILDTHING TAZ is offline
Old 02-21-2004 | 05:26 AM
I have been using the GL4 Amsoil in two different boats TRS drives owned over the past 6 years ....no problems...Fred
fred is offline
Old 02-29-2004 | 05:32 AM
bobbarker's Avatar
Default gearlube
My boatis a 357with #3speedmasters I was told by amsoil to use marine 90. I also use 2000 severe use
20w50w racing oil, change every25-30hrs. I run the hell
out of it an have had no engine or outdrive problems. I always talk to amsoil techs. if I have a question They always seem to know what their talking about.
bobbarker is offline
Griswald
Drives and Lower Units
3
12-08-2007 03:20 PM
ninetym
5
11-06-2007 05:43 PM
96f350psd
15
06-07-2005 06:44 AM
traviss
17
03-08-2004 05:06 AM
kook
4
07-07-2002 05:46 PM
