How much steam is too much? >
Old 02-27-2004 | 07:09 PM
Danny_Ocean
Default How much steam is too much?
I'm observing whisps of "steam" coming from my exhaust. More at WOT than at idle. Boat is BBC, raw-water cooled with thru-hull wet exhaust (stock Mercruiser manifolds/risers). No visible problems exist and water temp is OK.
How much steam is acceptable?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 02-27-2004 | 07:20 PM
blue thunder's Avatar
How does one see whisps of steam at WOT? Seems like it may be hard to detect. Plums of steam maybe, whisps, no.
BT
blue thunder is offline
Old 02-27-2004 | 07:36 PM
Ric232
Default Re: How much steam is too much?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
There should not be much. Replace your sea water pump impeller first. If that does not fix it, you may have an issue with the exhaust risers.
Old 02-27-2004 | 09:40 PM
Danny_Ocean
>There should not be much. Replace your sea water >pump impeller first. If that does not fix it, you may >have an issue with the exhaust risers.
The exhaust risers are old. What kind of "issues" might they have?
>How does one see whisps of steam at WOT? Seems >like it may be hard to detect. Plums of steam maybe, >whisps, no.
Well, "plume" isn't how I would describe it. "Whisp" is more like it.
D. Ocean
Pompano Beach, FLA
Old 02-27-2004 | 09:54 PM
puder's Avatar
speel chekk this fokker!
riser issue are leaks.
water leask back down into your engine and can cuase it to eat itself. Thats not good.
if you see any water weepign fron teh manifold or riser on the outside you can bet your ass you have leaks one the inside.
replace with soe kind of aftermarket manifodl or header. Stock merc manifodl are notorious for leaking and premature failure.
Pardon me, while I whip this out!
puder is offline
Old 02-28-2004 | 09:33 AM
mlitefan
I get a lot of steam out of my starboard side after a hard run. It lasts a minute or two and then starts to dissipate. I added lightning headers last year as well and had the steam with stock manifolds. I also put in a new impeller and still have the steam. It seems to be fairly normal?
Old 02-28-2004 | 09:41 AM
Another problem with exhaust and risers is they can become clogged by the iron scale from the corrosion process. This will restrict the water flow and cause hot spots which could create steam. Sometimes you can detect this externally by feeling the "firmness" of the water hose that feeds the exhaust while the engine is running. If it is hard, you have restriction and the exhaust needs to be serviced. Scale and corrosion is removed by soaking the manifolds and risers in muratic acid, rodding out, soaking again, then flushing with fresh water.
BT
Old 02-28-2004 | 01:05 PM
My bet is that your risers gaskets are leaking.
I was seeing a lot of steam with my Gil Exhaust and both manifolds had internal cracks.
Griff is offline
Old 02-28-2004 | 03:40 PM
formula31's Avatar
Thats normal. If the exhaust steams on start up or while running and the water is not real cold, look for cracked head. Found out the hard way.
formula31 is offline
Old 02-28-2004 | 03:41 PM
formula31's Avatar
After you check the manifolds and risers of course
kemiller
8
05-06-2007 11:06 AM
cstobe
12-03-2006 05:51 PM
86formula242ls
05-24-2006 08:43 PM
MnFastBoat
4
07-11-2005 04:27 PM
