Mirage conversion to ACCLERATOR >
Old 06-17-2004 | 12:06 PM
  #91
HOUSTONPROP's Avatar
Default Re: Mirage conversion to ACCLERATOR
Rob,your prop is being shipped Monday.we will give you a tracking number if you want just let me know,Thanks for your Business.
HOUSTONPROP is offline
Old 06-17-2004 | 12:12 PM
  #92
Rob,Thanks for keeping me in line.The prop will be shipped overnight and be there in the afternoon. Thanks
Old 06-17-2004 | 12:25 PM
  #93
Leathl_WS6's Avatar
Thanks Darin. Great Service. I can't wait to get it. I'll be planning a trip for the weekend now.
Rob
Leathl_WS6 is offline
Old 06-17-2004 | 01:55 PM
  #94
Rambunctious's Avatar
Hi darin
i got my props back before my first outing as promised..THANKS!!!!.
saw 1.5 mph improvement !!!!!
rpm is ever so slightly high for my 330's at 4700 on cool night, lightly loaded.
last night with 99.9% humidity and 84 deg. i was back in range of 4500-4600 for my 330hp.
i do see some porposing at cruise 40mph, 3000rpm and require some tab to settle.
i also see the props starting to spin out slightly at my max trim postion that was used previous. (preset with my merc trim limit switches)
would you add some slightly more cup to fix porpose and maybe pull a little more mph while dropping rpm???
or....I'l back up... do you have any suggestions.....after all your the expert
also, what is your current turn around for reworks (fine tuning actually)
thanks !!
Rob from Holland
Rambunctious
Rambunctious is offline
Old 06-17-2004 | 02:00 PM
  #95
Hello Rob,I think you or we are off by 1.5 3 mph is our normal gain so,yes we can re-work them to get a little more and hopefully reduce some of the porpoising.The turnaround on re-work on yours will be one day in shop after the day of arrival(which is usually around 3:00) BUT sounds as if we are very close .
How was the mid range ACCELERATION was it the same ,stronger,weaker or what?let me know what you would like to do .Thanks again
Old 06-17-2004 | 03:18 PM
  #96
thanks Darin
Accelleration did feel improved. my buddies 29 PQ used to plane faster and get me on the first 1000 ft. now i beat him!!!. but he still pulls on top end. so a tweaking we will go!!!!!!
I will send props for monday arrrival. would like them back in Michigan before the end of that week.
let's pull down 100rpm with rework and I think we will be there!!!
thanks Darin
Rob
Old 06-17-2004 | 09:37 PM
  #97
will do,I will call you when they arrive and we can PROP Talk a little more.
Old 06-18-2004 | 11:04 PM
  #98
Plum_Crazy's Avatar
Do these Accelerator props have paper-thin sharp edges? I'm interested in this mod, but I can't have a delicate prop. When the lakes are low, you can't help but hit bottom on occasion while beaching or driving on the trailer. There's also alot of debris in the Mississippi River. Can the Accelerator handle this stuff like a stock Mirage Plus?
Plum_Crazy is offline
Old 07-08-2004 | 11:26 PM
  #99
The Acclerator is thinned and has nice rouned edges,razor sharp edges are per request.
Old 07-11-2004 | 03:13 AM
  #100
New And Labbed Finished
BRAVO-ONE ANY PITCH YOU WANT LABBED AND READY TO GO
standard hub kits included.
shipping extra
[SIZE=6]labbing of your prop in shop 3 day turnaround .
