Mirage conversion to ACCLERATOR >
Old 05-20-2004 | 11:31 AM
  #71
Official OSO boat whore
Default Re: Mirage conversion to ACCLERATOR
I want to say THANKS to HP for getting me a fast and accurate prop replacement quote. They definetly went above the call of duty! Thanks guys! I'm certain that they can handle your propeller needs.
Cord is offline
Old 05-20-2004 | 12:34 PM
  #72
jspeeddemon's Avatar
Darin can you give a prop recommendation for a 22' scarab with a BBC 468 running low 70's right now. Would like to trim a bit more and gain additional speed if possible, running a 26" x 14.625 dia 3 blade right now and pulling it to 5100, rev limiter not an issue, motor can handle 5400-5500 with the cam.
jspeeddemon is offline
Old 05-25-2004 | 12:09 PM
  #73
HOUSTONPROP's Avatar
questin most 26 pitch props are a four blade or else yours a 25p has been worked to a 26 any idea what type of prop you currently have,let me know Darin.
HOUSTONPROP is offline
Old 05-26-2004 | 08:49 AM
  #74
The 26 is a borrowed prop from a friend and I'll have to ask him the details. How far can you twist a 23 P Mirage prop, it was just not enough. As well the boat does not react well to more than a little trim, it begins losing grip and then it starts to chine walk slighlty, would a 4 blade help with these symptoms?
Old 05-26-2004 | 04:48 PM
  #75
Talking Re: Mirage conversion to ACCLERATOR
jspeedemon you may want to consider a four blade if you do not like the handling of a 3 blade prop a Bravo-one would be the next best thing labbed of course,we have them ready to ship or we can convert your Mirage to the acclerator and we can change the pitch 2"or in (mean) pitch 1.5 with some extra cupping will work fine.give me a call if you need to ?
Darin
Old 05-28-2004 | 06:18 AM
  #76
Hey Darin. Tried sending you a regular e-mail this a.m. and got it returned as undeliverable. Any thoughts?
bouncedcheque is offline
Old 05-28-2004 | 09:53 PM
  #77
[email protected]
Old 05-29-2004 | 11:11 AM
  #78
outriggers's Avatar
Darin, I have a BB 22' Scarab and haven't had much luck with either a 23 mirage or 25 mirage+. Last year I put a new 22 bravo on it and I like the results, but I need more pitch. 60mph@5000 How do you think a Acclerator would for me? Does it make any differance if you start with plain mirage or a + ? Thanks, Doug
outriggers is offline
Old 06-02-2004 | 07:13 AM
  #79
Doug a Mirage plus would be better to work with there is a better blade area to work with,you find a big difference between the ACCLERATOR AND A STOCK PROP.
Old 06-02-2004 | 10:40 AM
  #80
outriggers's Avatar
Darin, Would you pm me with a price to convert my 25 Mirage+ to a Acclerator? What kind of turn-around time can I expect at this time? Thanks, Doug
