Mirage conversion to ACCLERATOR >
Old 04-05-2004 | 10:30 PM
  #41
HOUSTONPROP's Avatar
Default Brian
give me a call when you can,turnaround time is around two weeks some have been longer,just depends on the daily load factor,which is very high right now,perfection takes time.
Thanks Darin
HOUSTONPROP is offline
Old 04-06-2004 | 04:08 AM
  #42
BAD-HABIT's Avatar
Default Re: Bad Habit
Originally posted by HOUSTONPROP
Randy we can work the 17 Mirage up to a 19 pitch and change it to our ACCLERATOR design which will work great and pull the rsssssssssssssssssssssss you need ,give me a call and we can talk more in detail,Thanks Darin
So are you saying that since my best speed was with the 21p Mirage not the 17"Mirage plus and my best rpms and accell was with the 17p ballistic that we shoud go with reworking the 17" Mirage Plus right? I got the same top end with a 21p Mirage as I did with the 17p Ballistic. The Mirage only pulled 4600rpm's and I need to be hitting 5300+. Sorry lots of questions Im just wanting to make sure I get everything straight in my head...That takes some doing sometimes By the way are YOU confused yet......
BH
BAD-HABIT is offline
Old 04-06-2004 | 10:19 AM
  #43
Lightbulb Bad-Habit
The rpms need to come up and the 21 is to low the 17 is to high so you need a 19 pitch mirage with the acclerator design,this will raise the rpm to where it needs to be and give you the best ALL AROUND performing prop.we can pitch the 21 to a 19 or 17 up to a 19 either way probably would be easier to work the 21 to the 19 pitch.
as far as converting the Ballistic to a ACCLERATOR it cant be done,wrong type of prop, it has to be a Mirage.
but since you don't like the solid hub on the 21 then use the 17 pitch mirage converting to the ACCLERATOR.
Old 04-09-2004 | 12:40 PM
  #44
mikev's Avatar
Hey Darin got my prop on wednesday and tried it out yesterday. it looks great cant believe it was the old quicksliver prop i sent you. results even though it was repitched from a 19 to a 21 the holeshot is better acceleration is better and top speed 2mph faster (on speedo i dont have gps) thanks I am very happy with it.
mikev is offline
Old 04-10-2004 | 10:52 AM
  #45
Default Thanks
We are happy,when you are happy
Have a great Holiday weekend !!!!!!!!!!!!!!!
Kim & Darin
Houston Propeller
Old 04-18-2004 | 10:15 AM
  #46
Default LABBED FIVE BLADES
ORDER YOURS TODAY ANY PITCH YOU WANT.
Old 04-25-2004 | 06:05 AM
  #47
Default CUSTOM FIVE BLADE PROPS
WITH SUCH A LARGE DIA PROP 15 1/2 AND any pitch you want we can slice and dice The blade to any shape we want for additional performance,These props are available in STERN and BOW lifting applications. order your CUSTOM PROP today at Houston Prop.
Old 04-26-2004 | 03:55 PM
  #48
boatn70's Avatar
Default did it go out last week???
hey darin,
did my 23 mirage go out as planned on wed last week?
hope so, cant wait to try it out!!!
thanks
kevin
boatn70 is offline
Old 04-26-2004 | 05:02 PM
  #49
Default boatn70
call me as we have four Kevins here.
Old 04-28-2004 | 08:09 AM
  #50
Thats Kevin from Rockford Il.
HPJunkie is offline
