Mirage conversion to ACCLERATOR
#61
Kevin Thanks for posting,I will gladly re-work the prop for you,we may need to thin a little more and reduce the cupping ,cupping is very crictal.
and if we add too much in the prop we blew-it.we just did not hit the spot on yours,we will take care of it, and get you the extra speed you deserve. ITS THERE to be had.
Thanks again, Darin
Thanks again, Darin
#62
hi darin finaly got to try my prop .got on plain much faster .then a little blow out ,trim up ,then it hit .was like hiting secont gear ..midrange was great ,top speed 5000rpm last years gas .73.8 gps great job darin .THANKS .
#64
Darin...I am wondering what the difference I should expect to see between a my Michagan Ballistic Prop labbed by you and A Mirage/Plus you re-work with your design. What would the difference be? I have 2 Ballistics a Mirage and a Mirage Plus...I really only need 2....So I need figure which ones to keep. I can PM you any info you need on figures etc.....Do you take trade ins?
Can't hurt to ask right
Randy
"Bad-Habit"
Randy
"Bad-Habit"
#66
Hey Darin,
I have run my new Accelerator twice now.
Great hole shot with no blowout!
Need to get out in some rough stuff and try it there.
Job Well Done.
Job Well Done.
Patrick
Patrick
#68
Also Darin,
can you post your email address. I must thave miss spelled as my email was returned. was forwarding pics of my 25 quicksilver for you to consider.
Rob from Holland, mich
Rambunctious
Rambunctious
#69
Darin, just wanted to let you know all is well with the prop. I ran this weekend and it handled just as it did when the prop was stock...only faster!
69.6 GPS and it had more but I backed out to keep from bouncing the wife around over a cruiser wake. Most of the porpoise issue is resolved! 5300 RPM
55~6 MPH at 3800 RPM
Thanks again Darin...Larry, Chesterfield VA
#70
mlitefan>Great news >Thanks again Larry for the Business and have a great weekend .
our e-mail address is >[email protected]
