best gear lube. >
best gear lube.
best gear lube.
Old 03-06-2004 | 02:55 PM
traviss's Avatar
Default best gear lube.
What is the best gear lube to use. I am going to pushing over 550 hp through my alpha this year and want the best protection i can get. Price is not a issue.
thanks
Travis
traviss is offline
Old 03-06-2004 | 03:35 PM
DanB's Avatar
Charter Member #71
Hi Travis
I've been using Amsoil 80W-90 synth in my Warlock B-1 and never had any issues. But if ya beat something hard enough its gonna break.
Dan
DanB is offline
Old 03-06-2004 | 03:37 PM
traviss's Avatar
Dan
LOL! Yup, that is true, its always in the back of my mind
traviss is offline
Old 03-06-2004 | 07:53 PM
Whitey's Avatar
Traviss I use Redline Shockproof heavy. I pulled my pinion out this winter and replaced a bad front seal and one thing I really noticed was the lube was still sticking to the gears after setting 3 months. have also noticed the redline likes to foam a little but, It does not seem to cause problems. Dwight
Whitey is offline
Old 03-06-2004 | 08:54 PM
traviss's Avatar
thanks dwight
traviss is offline
Old 03-06-2004 | 08:59 PM
Whitey's Avatar
Us mouse guys have to hang together
Whitey is offline
Old 03-06-2004 | 09:03 PM
traviss's Avatar
ohh yeah!
traviss is offline
Old 03-06-2004 | 09:06 PM
28SCARAB's Avatar
What is the best gear lube to use. I am going to pushing over 550 hp through my alpha this year. I thought I had Balls
28SCARAB is offline
Old 03-06-2004 | 09:16 PM
traviss's Avatar
LOL! I am crossing my fingers! if you can work the stick, you will save any drive
I pushed a little over 500 through it last year, took it apart today and no problems to be seen. been using mercury high performance lube.
traviss is offline
Old 03-06-2004 | 09:23 PM
Whitey's Avatar
Traviss this is a little off topic but what do you seal the rocker arm studs with? Dwight
Whitey is offline
