bravo 1
Old 03-10-2004 | 08:42 PM
johnnyboatman's Avatar
Default bravo 1
was looking at the props on my boat and noticed a few drops of gear lube inside of prop. where is the seal, has set since november. how hard are they to change.
johnnyboatman is offline
Old 03-10-2004 | 09:12 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The 2 prop seals are in the inside of bearing carrier. It has to be removed to replace the seals. Need special tools. Depending on yr of drive, determines if the carrier gets retorqed or bearing preload reset.
US1 Fountain is offline
Old 03-10-2004 | 10:44 PM
Johnnyboatman, pm me if you need any help with it, local in the city. it could be prop shaft seals, or the oil drain seal. can pressure test it to make sure where at for ya if needed.
JPD Motorsports is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
