Tbolt ignition module >
Old 03-12-2004 | 05:39 AM
KH0302's Avatar
Default Tbolt ignition module
Guys, this thing was mounted stock flat against the riser. Did they do that for a reason, i.e. so it would feel heat? I want to mount it to the transom, is that cool?
Thanks again for the help. The tips I've gotten here far outweigh the measly membership fee I paid!
Kurt
KH0302 is offline
Old 03-12-2004 | 06:27 AM
cig1988's Avatar
It should have 3 fiber washers between the bracket and riser. Must be non metal to prevent heat transfer.
cig1988 is offline
Old 03-12-2004 | 06:32 AM
KH0302's Avatar
Ok, the riser is gone, replaced by a header, that's why I need to relocate it. So I hear you say no it doesn't need/want to get hot, so the transom will be fine?
Kurt
KH0302 is offline
Old 03-12-2004 | 06:54 AM
marinetrans's Avatar
Just run a new ground from the motor to the case of the module( connect the ground from module to this too).
marinetrans is offline
Old 03-12-2004 | 08:32 AM
aero-offshore's Avatar
Merc mounts them on the riser or manifold for easy installation of the engine as one unit.
aero-offshore is offline
Old 03-12-2004 | 04:14 PM
KH0302's Avatar
Thanks a million, guys.
KH0302 is offline
Old 03-12-2004 | 10:06 PM
glassdave's Avatar
Neno the mind boggler
i mounted mine on the transom a few years ago after doing a similar exhaust conversion. no problems so far.
08 OPA High Points Champion
glassdave is offline
Old 03-13-2004 | 03:48 AM
Both the ground on the module and the case must be grounded as he said. When its mounted on the riser, the case gets grounded through the connecting bolts. If the case isn't grounded you won't get any spark. I mounted mine on the transom and learned this the hard way.
Griff is offline
Old 03-13-2004 | 05:17 AM
KH0302's Avatar
griff, isn't that the stuff one NEVER forgets? Grazie for the heads up, I was going to just extend the black lead and run it back to the engine.
KH0302 is offline
Old 03-14-2004 | 02:12 AM
Thats what I did the first time.
Run the black module wire to one of the mounting bolts on the case/bracket and then run a wire from there to the engine block.
Griff is offline
shawn
05-25-2007 05:03 PM
Gary Anderson
10
05-24-2004 09:43 AM
Gary Anderson
7
08-16-2003 08:23 AM
BAD-HABIT
2
01-28-2003 09:05 PM
klmken
4
04-15-2002 11:15 PM
