Oil Drain Tubes >
Oil Drain Tubes
Oil Drain Tubes
Old 01-30-2002 | 08:34 AM
Dave M's Avatar
Veteran: Navy
Post Oil Drain Tubes
I want to put an oil drain tube on my '97 454 mag. I am trying to figure out if I have the metric or standard plug. The bolt that is in there now seems to be 15MM. I was told that some engines of that year were standard and some were metric? Any idea?
Dave M.
Dave M is offline
Old 01-30-2002 | 09:16 AM
Brad Perry
Post
12mm x 1.75....look at post on first page of tech Q&A. '97 should definitely be a gen VI motor. If the timing cover is cast aluminum rather than stamped steel, then it is.
Old 01-30-2002 | 06:41 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Post
I FOUND THAT THEY MAKE 2 SIZES 9MM & 1/2-20 THREADS. WEST MARINE SELLS A BRASS 90 DEGREE FITTING THAT SCREWS INTO PAN THAT YOU SCREW A STANDARD FLAIR FITTING ONTO.JUST PULL PLUG OUT OF PAN AND MATCH THREADS UP IF YOU CANT TELL WHAT THREAD SIZE YOU HAVE.I USE THEM & THEY WORK WELL.I USE A LITTLE PUMP YOU BUY IN WALLMART ON A CORDLESS DRILL TO PUMP OIL OUT.
WILDTHING TAZ is offline
boatman22
Sutphen
9
01-24-2006 08:34 PM
boatinbill
Sunsation
4
09-19-2004 08:55 PM
klaw
1
07-28-2004 01:24 PM
ThirdBird
6
09-27-2002 07:32 PM
Valley Boy
8
02-19-2002 08:13 PM
