Masterlube Installation ??? >
Old 03-17-2004 | 06:12 PM
Question Masterlube Installation ???
ok, asked this question in general area with no takers.
Where is the best location to tap into the motor or oil filter location from the masterlube cylinder. The motor is a 500EFI, and it will be used as a preluber?
Suggestions??
Thunder32 is offline
Old 03-17-2004 | 08:41 PM
wwwTOPDJcom's Avatar
I too wondered this, but I found that a bottom of the webpage
http://accusump.com/acc_products/acc_units.html
unit is easier to install
wwwTOPDJcom is offline
Old 03-17-2004 | 08:47 PM
marinetrans's Avatar
I put a couple of those on some boats. Where the oil sender is, I put a tee there, oil sender on one side and the Masterlube hose on the other side. No problems w/ 2 seasons.
marinetrans is offline
Old 03-17-2004 | 08:54 PM
otherside of what dont you need the intake for the masterlube on the pan?
Old 03-17-2004 | 09:27 PM
Ric232
Old 03-18-2004 | 12:22 AM
I have one of these installed on my 575sci which should be the same install as the 500efi. I'll have to look but I think it's installed to a oil rail plug that's easy to remove on the port side.
zahndok is offline
Old 03-18-2004 | 01:33 PM
dlbCheckmate's Avatar
Yes, any one of the rail plugs can be used. The port side has several. I use the one next to the oil sender.
dlbCheckmate is offline
Blue242
11
06-04-2008 01:41 PM
BajaBennett
10
11-29-2005 03:13 PM
Thunder32
03-17-2004 05:58 PM
ccarloss
7
11-21-2002 03:43 AM
sheikman
1
03-24-2002 08:25 PM
