Little crush or compression washers?!? >
Old 03-29-2004 | 01:09 PM
Von Bongo's Avatar
Default Little crush or compression washers?!?
Where in the heck can I get the little nylon or plastic compression washers for the hook up for my water pressure fitting on the engine block?
I can't find them at west or eddie or anywhere. It's a small hose and the setup screws into the block and has a small fitting that the hose fits on, then a compression washer and then a nut with the center cut out for the hose goes over it.
This is driving me nuts I need 1 but I would like to get a bunch, The fitting that the hose goes to has no barbs.
help if you can.
Mike
Von Bongo is offline
Old 03-29-2004 | 01:36 PM
later's Avatar
Mike,
Are you sure its not a flaired fitting with no washers needed?
I'm planning on being in the water next weekend you going to be out?
later
Dave
later is offline
Old 03-29-2004 | 01:43 PM
Von Bongo's Avatar
Hi Dave,
No the fitting is strait, no flare and no barbs. Althouhg I could replace it with such if I could find one of those.
Next weekend I am going to Dallas to see the neck car race. Friend has rented a condo that overlooks track. It's half condo and half skybox so I am pretty pumped. But I will be out the following weekend if I can find the part I need
Old 03-29-2004 | 08:30 PM
Von, try some of the local hardware stores. I know Westlake carries a lot of that of that stuff.
Griff is offline
Old 03-29-2004 | 10:51 PM
Reed Jensen's Avatar
if all else fails... you can order a million of them from www.bokers.com........
Reed Jensen is offline
Old 03-30-2004 | 10:35 PM
Check out the auto parts stores. Those same parts are used on the air hose for the Hadley air horns. Hadley sells them in a bag as replacement parts. I have a bag of them out in my garage somewhere. They've saved my a$$ on quite a few jobs.
Liberator21 is offline
ctadams21
7
04-01-2007 01:11 PM
BOATING ON A BUDGET
4
02-14-2005 09:31 PM
Mr Gadgets
10
06-06-2004 12:26 PM
SHARKEY-IMAGES
07-05-2003 04:44 PM
