Gen IV camshaft end play >
Old 03-29-2004 | 01:54 PM
Default Gen IV camshaft end play
I have a problem with the end play of my Gen IV camshaft. It has about 1/4" Now granted the timing chain is loose, need to replace the gear set as well. There are no thrust washers installed, do I need one. My cam was wore down because of it. Any suggestions would be welcome.
steve stanko is offline
Old 03-29-2004 | 02:40 PM
cstraub69@comcast
You need a cam walk button. End play should be between .004 and .007". Use a good reinforced USA made cover or the button will work through it. The Chinese covers are junk and will not hold up.
Chris
38KV's Avatar
You did not tell if the distributor was in place when you noticed that endplay. If the distributor is out, 1/4" endplay is normal on a stock gen IV.
38KV is offline
Old 03-29-2004 | 02:51 PM
I put the distibuter in without the intake manifold in place. But did see an abnormal amount of wear on the front lobes of the camshaft. I will try it with the manifold in place.
Old 03-29-2004 | 08:27 PM
Shouldn't really need a button with a flat tapet cam, but it won't hurt.
Flat tappet cam lobes are angled, so the downforce of the lifters actually pushes the cam toward the rear of the engine.
Griff is offline
Old 03-29-2004 | 08:48 PM
Tinkerer's Avatar
What GRIFF said.
Tinkerer is offline
Old 03-30-2004 | 07:03 AM
Thanks, I will just replace the cam and gear set and be quiet.
Old 03-30-2004 | 02:51 PM
WE NEED TO KNOW WHAT TYPE OF CAM IT IS AND HOW YOU MEASURED THE END PLAY IF ITS A HYDRAULIC YOU WILL GET A LOT OF END PLAY IF YOU WANT CALL ME AND ILL WALK YOU THROUGH WHAT YOU NEED TO DO TO FIX IT LAZ MESA 1-305-884-5368 WWW.MESABALANCING.COM
MESABALANCING is offline
GNJ
3
05-23-2007 12:15 PM
502SCS
13
02-14-2005 10:44 AM
KNOT-RIGHT
1
12-11-2003 03:29 PM
Ric232
8
04-13-2003 02:22 PM
FunHome
06-10-2002 11:12 AM
