Pros/Cons of a cleaver prop? >
Old 03-30-2004 | 11:29 PM
Danny_Ocean
Default Pros/Cons of a cleaver prop?
I'm currently running a Mercruiser Mirage (round-ear) prop, 14 5/8" x 23" pitch. I've found a good deal on a cleaver prop in the same configuration. Any advantage/disadvantage to running a cleaver? Boat is 26' Corsa w/454-330 & TRS.
Not seeking top-speed, more interested in efficiency.
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 03-31-2004 | 06:23 AM
throttleup's Avatar
The cleaver won't be what you want. The cleaver is a prop that typically delivers good top speed but a poor mid range and hole shot.
I assume you are referring to a "can cleaver". Used ones are usually available pretty cheap.
The Mirage is a good prop when mated to the TRS drive as it is usually mounted deep in the water.
What kind of speed and rpm do you see now?
throttleup is offline
Old 03-31-2004 | 08:20 AM
Danny_Ocean
Not sure. Haven't had the boat in the water since I purchased it. Next week!
D. Ocean
Pompano Beach, FLA
blownincome
Fountain
11
12-21-2021 08:19 PM
DMAX
28
01-10-2006 03:31 PM
Outkast Rafe
08-18-2005 07:12 PM
LutzParty
08-29-2003 11:23 AM
Montauk Crossbow
11-25-2002 08:07 PM
