#1 tip to add to your spring checklist >
Old 04-06-2004 | 10:21 AM
Caincando1's Avatar
Default #1 tip to add to your spring checklist
Check your motor mounts!
Merc's motor mounts are notorious for coming loose. Seems just about everyone that I boat with have had the motor mounts work loose at one point or another. Some boating buddies just spent 6 hours Saturday re-aligning both engines due to loose motor mounts.
Brian
Caincando1 is offline
Old 04-06-2004 | 10:37 AM
Official OSO boat whore
I know that I have a bolt that's visibly loose from last year. How it loosened I have no idea. It has a lock nut on the thing.
Cord is offline
Old 04-06-2004 | 07:05 PM
blue thunder's Avatar
I have found if you replace the lockwasher/nut that are stock for those mounts and replace with nylon insert nuts they do not come loose any more. I still bend the tabs over but that never seems to work for me by itself.
BT
blue thunder is offline
Old 04-06-2004 | 07:55 PM
easier fix, i removed the lock washer, and stacked stainless washers. once you have the engines aligned, and there is a solid base under the lower nut, there is no way the mounts can loosen. just tighten the top nylon insert nut, and your done...
KBUSH1 is offline
88242LS
04-17-2008 03:04 AM
MILD THUNDER
4
03-08-2007 06:25 PM
Hot4Teacher
1
08-11-2006 11:22 PM
saubouin
08-04-2005 07:12 PM
seanclong
03-27-2002 07:25 PM
