Finally got it started now it knocks >
Old 04-07-2004 | 09:40 AM
bowtie89
Default Finally got it started now it knocks
OK I finally got the boat to start doing a whole tune-up (cap rotor wires and plugs) I haven't changed the oil yet so that is what I will do next prefferably synthetic!! what weight should I use for an 89 350 magnum!!
Ok the problem now that I got it started its knocking or tapping I am not sure yet I didn't want to run it with the old oil in it! But It hasn't run since September? any ideas or things to check out?
Old 04-07-2004 | 10:07 AM
mcollinstn's Avatar
Could be a bunch of things.
Collapsed lifter is likely after sitting that long.
Be sure your wires are on in the proper firing order.
There's three knocks.
Taps (from the upper end).
Taps (from the lower end).
Clunks (from the lower end).
They are all a different degree of bad.
mcollinstn is offline
Old 04-07-2004 | 10:15 AM
marinetrans's Avatar
Riser gaskets leaked. May have hung an exhaust valve.
marinetrans is offline
Old 04-07-2004 | 11:11 AM
dyno's Avatar
Charter Member #655
Bummer
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-07-2004 | 12:05 PM
bowtie89
I didn't think you would know based on my limited information! I am going to change the oil today or then next day! What should I use?
Old 04-07-2004 | 12:30 PM
ISurvivedNMU
Synthetic will clean your engine and could make older engines clunk or tap...... Its thinner... Maybe worth it to clean things out, but you will most likely go back to dino......
Old 04-07-2004 | 02:05 PM
bowtie89
what is back to dino? I don't mean to sound like a rookie!!
Old 04-07-2004 | 02:42 PM
Iggy's Avatar
"Dino" refers to regular oil, the natural type, non-synthetic.
As in crude oil, which comes from the decayed remains of dinosaurs (dino), trees, plants, etc.
Iggy is offline
Old 04-07-2004 | 09:29 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
SOUNDS LIKE MY LUCK DON'T YOU JUST LOVE BOATING. IT'S LIKE KIDS IT CAN BE SO UNREWARDING
WILDTHING TAZ is offline
Old 04-07-2004 | 09:39 PM
How long did you let it run? Long enough for it to build pressure. everything will be bone dry but the pan since it sat for that long.
Wildthing taz I know what your talking about with the luck 3 froze brokes thanks to detailers
JPD Motorsports is offline
