Whose drive reservoir foams and whose doesn't??? >
Old 04-07-2004 | 10:26 PM
Danny_Ocean
Default Whose drive reservoir foams and whose doesn't???
I've searched the forum and, after much informative reading, decided to go with RedLine Heavy in my drive. However, there seems to be two factions: Those whose drive reservoirs foam with the RedLine and those whose do not. I want to avoid the hassle of the foaming mess, so trying to figure if I am a candidate...Is it high HP only or a certain type of drive? There must be some explanation as to why some foam but not all?!?
My setup is a stock 330/454 w/TRS.
Many thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 04-07-2004 | 11:34 PM
I run a 500hp with a standard Bravo 1 drive it also runs a drive shower and I have not had any problem with the Red Line foaming up.
It is a sticky oil. I'm changing to Royal Purple Max Gear as I feel it is a better oil.
Active Mike is offline
Old 04-08-2004 | 12:18 AM
Downtown42's Avatar
I run Merc Hi-per and never even heard of rabid-dog-foaming till I read what others have. Stock 502-Bravo 1's
Downtown42 is offline
Old 04-08-2004 | 12:31 AM
Strip Poker 388's Avatar
Rob
On my old scarab I ran Aslyn syn and it foamed went back to merc oil and no probs.
The Hustler has B maxs and they recommend syn- I run amsoil and it foams . When you stop it settles back to where it was. no problems though.
Strip Poker 388 is offline
cobra marty
07-02-2007 10:11 AM
teaguecustommarine
New Products and Member Discounts
1
07-31-2006 05:42 PM
NickOTeen
8
07-25-2005 03:31 PM
RedDog382
1
05-04-2004 08:13 PM
baronbob
25
05-01-2004 05:32 PM
