fuel pump relay? >
fuel pump relay?
fuel pump relay?
Old 04-08-2004 | 08:48 PM
Question fuel pump relay?
Getting ready to install an electric fuel pumpon a small block carbed motor.I've got all the parts,pump,reg,gauge,inline fuse,low oil pressure cut out switch and relay.The cut off switch came with a wiring diagram wich does not include a relay.Is a relay really needed or should I leave it out.The pump is a mallory 140 gph unit and calls for a 7.5 amp fuse.What do you think,yes or no?
magnum is offline
Old 04-09-2004 | 09:24 AM
Depends on the amount of current going through your ignition switch. If it's just the starter solenoid, Tbolt ignition, and the fuel pump, you're probably OK without the relay if your wiring is good (14g or bigger to the key switch). Just be sure you're not seeing a voltage drop across the ignition switch. Corrosion will cause this frequently in boats. Low voltage wont hurt the ignition, but ruins fuel pumps fast.
Gary
Gary Anderson is offline
Old 04-09-2004 | 09:57 AM
Yes, a realy should be used.
Running power from your battery up to the ignition switch, back to your oil pressure safety switch and then to your fuel pump will cut the voltage. Simple resistance.
Fuel pump us DC motors which are voltage sensitive, more voltage more fuel.
Run a relay, directly to the battery, and to the fuel pump, and then use your oil pressure safety switch to turn the realy on and off. This will ensure you get full voltage to the pump, and optimal performance.
RumRunner is offline
Old 04-09-2004 | 11:51 AM
In your post, you say it came with a relay. If that's the case, you would wire the low oil pressure cut off switch in series with the ignition switch, and relay coil. This way, if you lose oil pressure, power to the relay is cut, the relay drops out, and your fuel pump shuts off. You don't want to wire the cut off switch in the fuel pump line directly, because it probably can't handle the fuel pump's current.
Paul
Liberator21 is offline
Old 04-09-2004 | 01:23 PM
Here's a little diagram.
Old 04-09-2004 | 01:28 PM
Can't post attachments anymore?
Old 04-09-2004 | 04:18 PM
Thanks guys,I'll be using the relay like RumRunner says.
magnum is offline
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
ctuck0659
0
06-20-2007 07:08 PM
