re-torque the heads >
re-torque the heads
re-torque the heads
Old 04-12-2004 | 11:17 PM
Default re-torque the heads
Do you retorque your heads.Last year I did not.I was thinking about doing it this time so should I fire her up on the hose and warm it up then retorque or would you wait and give her and day of open water and some WOT first. I am running the GM marine head gasket this year again.Thanks James
FloridianSon is offline
Old 04-13-2004 | 12:12 AM
Never touch um after the initial install and initial retorque.
Griff is offline
Old 04-13-2004 | 12:29 AM
Reed Jensen's Avatar
I never re-torque after the first re-torque during assembly...
Reed Jensen is offline
Old 04-13-2004 | 07:21 AM
formula31's Avatar
Me neither. But im using fel-pro.
formula31 is offline
Old 04-13-2004 | 01:48 PM
felpro for me too.
Griff is offline
Old 04-13-2004 | 05:13 PM
BAD-HABIT's Avatar
Call the MFG and ask their recomendation.....
BH
BAD-HABIT is offline
Old 04-13-2004 | 07:23 PM
blue thunder's Avatar
That's how I do it. Torque in many steps up to desired torque. Then let sit over night and come back through and tap the head of each bolt with a hammer, then torque again to desired torque. I usually get a little out of a couple of the bolts the second time around. Just the same as when I used to run the engine, let cool and retorque. Just a whole lot easier.
BT
blue thunder is offline
Old 04-13-2004 | 10:21 PM
Rather than tap the bolts... I just back them off and then re-torque. I'm used to finished chrome acorn head nuts... don't want to hammer them.....
Smitty
3
05-04-2008 10:31 AM
fastlane40
5
01-29-2008 06:31 AM
iamfaster
3
01-08-2005 06:48 PM
Dave1972
6
12-09-2003 02:16 PM
Tom
12-22-2002 06:11 PM
